300CE few pics of the possible problem
Old Feb 18, 2008 | 11:13 PM
Benz_300ce's Avatar
1991 Mercedes 300CE
Here i got few pics and what it looks like some sort of sensor that is broken and its not connected, i was just wondering if that Small Part showing in the picture has a big affect in the cars performance and if someone can tell me what is that called so i can search to buy it. thanx
Old Feb 19, 2008 | 12:49 AM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
Looks like either a mangled hot film mass air flow sensor or an intake air temp sensor. In either case there should be a hole for it in the intake between the air filter and the throttle plate.
Old Feb 20, 2008 | 11:33 PM
pifcat2's Avatar
300TE / 300E / 300CE
According to the manual it's a camshaft position sensor. Mine has exposed wires and occasionally prevents my CE from starting.
Attached Thumbnails 300CE few pics of the possible problem-cam-position-sensor.jpg
Old Feb 20, 2008 | 11:49 PM
shdoug's Avatar
You're right. It may also prevent the valve timing from advancing which will reduce power output.
Old Feb 21, 2008 | 12:53 AM
pifcat2's Avatar
more info:
Attached Thumbnails 300CE few pics of the possible problem-cam-position-sensor-replace.jpg
Old Feb 22, 2008 | 08:04 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
more info:
^+1
Old Feb 23, 2008 | 12:24 PM
Parshman's Avatar
300E
If its that timing sensor then its going to cost you a lot of money and its a special order piece. I think it was like 300 dollars for that little sensor, if not more. Oh make sure you have the O-ring that goes with that or you'll have a nice oil leak( from experience)
