18x8.5 e5 35 rear wheel issue
Old 02-20-2008, 01:00 AM
decorated1's Avatar
1994 e320
I tried to put the rear wheel carlsson 1/6 18x8.5 et 35 the wheel will not move , i am not using a spacer yet I am however using the stock lug bolts, anybody had the same experience before? could it be the lug bolts are hitting it all the way thru or the caliper is on the way the struts are way clear, the fronts are cleared too with the stock suspension, any suggestions as how and what to do? appreciate the help, thanks!
Old 02-20-2008, 01:23 AM
190E 16V's Avatar
1987 560SL
Perhaps the stock bolts with aftermarket wheels are too long as you suggest.
I had the same issue with my Lorinsers. The fronts are not an issue, but the rears, if too long, will hit the emergency brake mechanism on the rear axle and not turn or damage those parts as they go around. My wheel shop said it is common to need to cut off a few threads when fitting aftermarket wheels on the rear of MB's.
Old 02-20-2008, 11:51 AM
jgajito's Avatar
1992 190E 2.6L
Originally Posted by decorated1
...I am however using the stock lug bolts, anybody had the same experience before? could it be the lug bolts are hitting it all the way thru...
BINGO! That's exactly what it is.
The solution:
Shorter bolts... as you would be able to see, the stock lugs are longer because of the OEM wheel fitting. Don't cut them off. I believe you have to go from an 85 or 61mm to a 2-inch. But first compare the length it sticks out from the after-market wheel to the oem wheel. The difference is what you want to downsize from. That's a much safer way to do it.
Depending on the manufacturer, you might have to go as low as 1 1/2-inch. These are available at most autoparts store.
Make sure that you also consider what the aftermarket wheel requires, a tapered or rounded head on the bolt. sometime just replacing a wheel isn't as easy as using the oem bolt. You may have to change your front bolts as well.
I used a 12 x 1.5 from Pep Boys for my ADR's w/ +35's.
Good Luck!
Old 02-20-2008, 11:57 PM
decorated1's Avatar
1994 e320
good info thanks for the suggestion, I will try to do the install this weekend, I have the same yr and color of your 124 ,jgajito, I have been looking for these color and the blue black whichever came first with the betrter condition it took me two year before this car came, thanks again will see what i will discover when I do the rears.
Old 02-21-2008, 03:15 AM
ZedStyle's Avatar
Youngtimer
do another quick test:
jack the car up, and put the bolts on, but don't tighten them all the way through, but enough so that they can take the weight of the wheel. then push the wheel all the way back to the hub, and see if it is contacting the brake caliper.
i had this happen to me, where the design of the back face of the rim was such that when i tightened the bolts, the wheel was tightening against the caliper on my front wheels, and it wouldn't rotate.
the solution was a spacer or new wheels, and i had bad luck with the spacers fitting properly on my front wheels (have 2 for sale, i give you good price ) so i got new wheels instead and called it a day.
just something else to consider
Old 02-21-2008, 12:26 PM
Bigpete123's Avatar
1990 300ce
yeah, definitely don't try to drive your car like that!!
Old 02-21-2008, 01:21 PM
childofjuly's Avatar
1995 E 420
i have some 1/6 evo diamond. 18x8 et 35mm with 225/40/18.. using stock factory lugs that came off my car. everything fit fine but my wheels is not 8.5" whats your offset? and what size tires are you using?
Old 02-21-2008, 01:31 PM
ZedStyle's Avatar
Youngtimer
Originally Posted by childofjuly
whats your offset?
18x8.5 et 35
Old 02-21-2008, 03:35 PM
joef's Avatar
S500
Keep us posted on how your car rides with the 8.5" wides wheels on. Rubbing issues, turning issues and so on. I haven't seen or heard of too many going with that wide of wheel, normally 8" is the widest.
Old 02-21-2008, 04:05 PM
berti_00's Avatar
2016 Cls63s AMG
mine are 18x8.5 all around
no rubing issues at all and mine is really low... only when i enter places it touches a bit in front but rearly... and i've had 4people in the car all 160+ pounds
***ZED were the hell have you been man...?
Old 02-21-2008, 04:11 PM
ZedStyle's Avatar
Youngtimer
what up man... i've been checking the progress on your car, it looks like it's about to f**k someone up! evil... i like it!
been busy with work and what have you, you know how it is...
that reminds me, i need to resurrect an old thread right quick.
Old 02-21-2008, 05:22 PM
joef's Avatar
S500
What offset?
Old 02-21-2008, 05:26 PM
berti_00's Avatar
2016 Cls63s AMG
What offset?
35
Old 02-22-2008, 12:14 AM
decorated1's Avatar
1994 e320
the tires came with the wheel 245x40 but I will use 225x40, the offset is et35, the fronts are clear of the struts has about 5mm or maybe more cearance that is visually have not measured it htough, it is the rear that is mind boggling but I will measure the lug bolts against the oem and carlsson and get the shorter if it does not work it is spacers i figured maybe also a 5mm spacer, but thanks for the info guys appreciate it
Old 02-22-2008, 11:05 AM
jgajito's Avatar
1992 190E 2.6L
One more thing... please do not forget to keep 5 original bolts in your car for the spare... after responding to this a couple of days ago, I had a flat, and guess what? the aftermarket bolts were too short for the OEM Spare... $8 a bolt at the closest dealer...
Old 02-22-2008, 02:16 PM
STLe320's Avatar
95 e320...sold the rest
but i believe berti has his fenders rolled...correct?
Old 02-22-2008, 02:22 PM
berti_00's Avatar
2016 Cls63s AMG
i do
Old 02-22-2008, 05:20 PM
STLe320's Avatar
yeh...i thought so. i plan to roll mine soon so i can get some 18x8.5 brabus wheels...like the ones in my sig (obviously fakes lol)
i'm 17...i wish i could afford that! lol
Old 02-22-2008, 05:59 PM
berti_00's Avatar
2016 Cls63s AMG
am 20 and broke ahhahah
Old 02-22-2008, 06:04 PM
STLe320's Avatar
haha well who isn't these days if you're under 25?
Old 02-22-2008, 07:33 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
so did you got it fix, post some pics
Old 02-22-2008, 10:19 PM
decorated1's Avatar
1994 e320
have yet to spend time I am doing it this weekend trial and error is the best way do this issue will post pics after the install, thanks!
Old 02-22-2008, 10:21 PM
decorated1's Avatar
1994 e320
thanks for the heads up , i am going to do that
Old 02-22-2008, 10:24 PM
ZedStyle's Avatar
Youngtimer
but you have a 600hp Evo... i'm much older than you, and i wish i could afford THAT...!
Old 02-22-2008, 10:25 PM
decorated1's Avatar
1994 e320
what is the thickness of the spacers, hub centric?and how much if you are to sell it?, thanks!
Quick Reply: 18x8.5 e5 35 rear wheel issue
