zed's request: valve cover removal
Old Mar 1, 2008 | 06:51 PM
GORBETTTEAM's Avatar
'95 3.2 M104
Cool zed's request: valve cover removal
NOTE: Numbers in parentheses ( ) indicate a component or tool in the associated illustration.
Remove cover (5) and ignition coils, then cover (7) and (6).
Unscrew bolts (14) and (15) with spacer sleeves (14a) and (15a).
Remove cylinder head cover (1) with gaskets (2) and (2a) and shaft seals (3). NOTE:
Remove grease from sealing groove and, existing reusable gasket (2) so that the gasket (2) adheres better to the cylinder head cover (1).
Do not grease new gasket.
Reverse procedure to install, noting the following:
Fasten cylinder head cover (1) to 10 Nm , see bolt diagram (illustration).
Run the engine.
Check for leaks, particularly at rear (arrows) at the gaskets (2a) and in the spark plug recess.
P.S.
Don't forget to purchase new seals(duuh) and the job like that pays about 1.7hrs + actuall head cover painting.... good luck.
Attached Thumbnails zed's request: valve cover removal-1.gif
Old Mar 1, 2008 | 06:56 PM
'95 3.2 M104
in case m103 engine
the removal and installation would take just a little over 1hr...
Attached Thumbnails zed's request: valve cover removal-42153253.jpg
Old Mar 1, 2008 | 07:32 PM
ZedStyle's Avatar
Youngtimer
thanks man!!
I'm a little scared to do this one though...!
Old Mar 1, 2008 | 10:20 PM
ksing44's Avatar
2010 VW Golf TDI
Originally Posted by ZedStyle
thanks man!!
Don't worry, the stealership will be happy to help you.
Old Mar 2, 2008 | 02:45 AM
'95 3.2 M104
Angry
ksingaway,
once again you proved to be smarter from everybody else.
now it's time for you to get off my thread.
Old Mar 2, 2008 | 04:26 AM
ZedStyle's Avatar
Youngtimer
maybe i'll just try to paint the small cover (#5 in the first diagram) and work my way up to the whole thing... the engine is one thing i'm always scared to play with - over-torque or strip a bolt, mess up a gasket, etc... much more $ than messing up a headlight retrofit!
Old Mar 2, 2008 | 10:06 AM
'95 3.2 M104
#5?
very easy. to be honest with you. i've been driving w/o that cover for about 6 months before i reached the results i wanted on my cover. it's about 30 mins job. good luck.
- gorb -
Old Mar 2, 2008 | 05:20 PM
ZedStyle's Avatar
Youngtimer
i noticed you managed to get a mercedes logo on there... how??
Old Mar 2, 2008 | 05:38 PM
'95 3.2 M104
Talking
yeah... I used something like this (silver aluminum decal w/clear coated cover):
http://cgi.ebay.com/ebaymotors/Merce...spagenameZWDVW
but from a different seller tho. i'll try to locate the guy if you want me to. let me know.
- gorb -
Old Mar 2, 2008 | 08:56 PM
ZorroAMG's Avatar
Enzo, my Benzo
Or you could use a rear mercedes emblem, clip off the little nipples that fit it to the trunk, jb weld it and voila, a 3D MB engine star!
Old Mar 2, 2008 | 10:26 PM
berti_00's Avatar
2016 Cls63s AMG
might be alittle to big??
Old Mar 2, 2008 | 10:34 PM
GEDaggett's Avatar
1994 E320 (current)
Buy a good set of torque wrenches
Hey Zed,
If you are concerned about over torque just break down and buy a nice set (craftsman) of torque wrenches. Get one for foot lbs (does your main bolts) and one for inch lbs (does the lighter stuff like covers and electrical components, etc). It will give you a heck of alot of confidence and you can also brag about it and feel more manly cause dude they are NICE BIG MANLY TOOLS. Even your lugs should be torqued to spec.
Old Mar 2, 2008 | 11:15 PM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
this might look familiar:
Old Mar 2, 2008 | 11:30 PM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
It's the star from the center hub cover....smaller then the trunk star !!!
Old Mar 2, 2008 | 11:43 PM
Thats what i meant by it looking familiar.
My engine bay looks like yours rbycc (stress on LIKE). Did 93+ look like gorbetts and zeds?
Old Mar 3, 2008 | 12:42 AM
ZedStyle's Avatar
Youngtimer
yeah, 93+ look like gorbs...
i have a torque wrench, but it's huge, probably need to get a smaller one i guess.
i also need the black plastic cover that goes on the front of the engine, mine is cracked. there was one on ebay a while ago for like 80 bucks, i thought that was a bit excessive
