need help
Old Mar 7, 2008 | 04:30 PM
cam346's Avatar
2010 ss and 2009 cts-v
need help
my 95 e320 front door goaning noises when I open it. what can I use to stop it,also my cruise control won't engage over 45. it also won't put out heat when it get cold out. any ideas on this. thanks
Old Mar 7, 2008 | 05:18 PM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
I must have sprayed half a can of WD-40 inside my door and an ounce of turbine oil. It made no difference at all. You may have to take the panel off.
No heat when it's cold outside is probably a bad thermostat if the engine does not warm up. If the engine does warm up but there's no heat or reduced heat, it's probably the monovalve/aux pump.
Old Mar 7, 2008 | 11:57 PM
GEDaggett's Avatar
1994 E320 (current)
There is some all purpose white grease in an aerosol can that might help with the door noise. It is a bit thicker than WD40 and will stay in the hinge for a good year. That might help.
Old Mar 8, 2008 | 12:36 AM
shdoug's Avatar
I think the problem is that you can't get the lube to the part that makes the noise without taking the panel off. There's something deep inside the mechanism.
Old Mar 8, 2008 | 10:56 AM
GEDaggett's Avatar
1994 E320 (current)
That makes sense. There are a lot of buried stuff under the skin of the 124. Guess that is how they accomplished the sleek look....and extra labor charges at the dealership.
Old Mar 8, 2008 | 12:55 PM
Bigpete123's Avatar
1990 300ce
Often the noise from the door opening and closing comes from a worn out "door check". It's that flat metal piece in the door jamb when you open the door... it's basically the only part in the door jamb that connects to the door and the body of the car and ISN'T a hinge. Here's the part; it isn't too expensive either:
http://catalog.worldpac.com/mercedes...art=Door+Check
Old Mar 8, 2008 | 12:59 PM
shdoug's Avatar
That almost looks like you could replace it without removing the door panel. Do you just unbolt it and slide it out? That's too easy!
Old Mar 9, 2008 | 09:23 AM
cam346's Avatar
thanks for the help. what about the cruisecontrol that won't hold over 50 and what vavle was that i needed for the heat.
Old Mar 9, 2008 | 10:01 AM
shdoug's Avatar
Does the engine reach temp when it's cold outside? If not , you just need a thermostat.
The other part is called a monovalve/aux pump. The following website calls it a heater valve solenoid. http://www.autopartsguru.com/RenderS...=autopartsguru
Old Mar 9, 2008 | 11:41 AM
PaulX608's Avatar
2011 VW cc, 2004 ML350
Nope, it goes inside the door and the bolts hold it in place from the outside. The is a third bolt you can only see with the panel removed as well. You'll want to replace this item before it breaks, as once it does, it can move around in there and damage things. Mine broke loose from the door and broke the window regulator the next time I put the window down.
Old Mar 9, 2008 | 04:06 PM
cam346's Avatar
yes it reach operating temp. what about cruise control. you guys are a great help. thanks
Old Mar 9, 2008 | 04:29 PM
shdoug's Avatar
Cruise control can be a lot of things. You'll probably have to take it to an expert for that. Sounds like your heat problem is the monovalve/aux pump, not the thermostat if the engine is warming up and still not much heat. For $275 I'd want to make sure. When the heat is on, you should be able to feel the pump spinning. It's in front of the battery.
