95 E320 brake Noise
95 E320, 2002 E430
95 E320 brake Noise
Hello from Atlanta! Particularly in hot weather, the front brake pads seem to be barely touching the rotors and making noise. When you barely touch the pedal, the noise stops. Also, when backing down a steep driveway, occassionally there's a pop noise. When it happens, I can feel a very short jump in the travel of the pedal. These symptoms reappeared even after rotors, front calipers and pads were replaced and the lines bled. The car stops ok, but has a scrungy sound at the end of stopping. Wondering if there's something wrong with the master cylinder or the abs system(no lights on yet). Any suggestions would be appreciated.
i now drive a ford p71 i also own a 1988 ford f150 lariat
my car dose the same thing and from what i read alot do the same thing i would not worry about it mine sqeek for no reson
When you replaced the brakes, did you use stock parts?
95 E320, 2002 E430
Thanks Chappy. Yeah, it's a one-time pop and usually happens as I'm backing down my steep driveway for the first time each day. According to the parts boxes, I used Textar pads and Bremsscheiben rotors, but the noise(s) were already there before I replaced those parts.
