Wheels... A quick question
Old Apr 2, 2008 | 06:32 PM
jeffreyli86's Avatar
What centre bore measurements do our 124s have?
Does anyone get wheels with smaller centre bores and then bore them out?
Do we have to have the correct centre bore?
Cheers
Old Apr 3, 2008 | 12:50 AM
YNVDIZW124's Avatar
lots of cars
66.59
Yes you can, I've done everything possible that can be done to a wheel. ( I also sell wheels )
Yes, you need the correct center bore so the rim can sit on the bore instead of the lugs. If you want to drive fast and your center bore is too big just get some hub centric rings.
Old Apr 3, 2008 | 01:21 AM
Originally Posted by YNVDIZW124
66.59
Cheers mate.
So all 5x112 rims can be bored out to the correct centre bore? I found some rims but they are in Audi bore.. I guess with a 5x112 that means there is room in the middle for me to bore out? I don't really want to get them and to find that it can't be done
Cheers
Old Apr 3, 2008 | 01:34 AM
YNVDIZW124's Avatar
lots of cars
Yes but audi wheels have a 14mm lug bolt. You will need either sleeves on the bolt or something to put them on. I had audi wheels on my car before but didn't really like the offset.
Old Apr 3, 2008 | 02:40 AM
Cheers.
Hmm.. Can I not use the lug bolts that I have on my AMGs now? Wouldn't they fit?
The Audi rims that I'm interested in are the same offset as mine now so I should be good to go..
Not sure how safe it is to enlarge the centre bore though...
Old Apr 3, 2008 | 03:16 AM
YNVDIZW124's Avatar
lots of cars
Cheers.
You have 12mm bolts right now and I used 2mm plastic sleev cut to size. If there is enough meat on the bore then it's safe because they only have to bore in about 4-5mm.
Old Apr 3, 2008 | 03:38 AM
Cheers mate
I'm by no means a wheel expert but I guess by 12mm 14mm you mean the bolt head right? If so, then wouldn't it be oK for me to use my existing bolts instead of the Audi ones?
From my understanding, the bore is there to help balance the wheel under high speed rather than take the pressure right? If so then I guess I'm safe with 4-5mm..
Cheers.
Old Apr 3, 2008 | 04:12 AM
ZedStyle's Avatar
Youngtimer
Originally Posted by jeffreyli86
Cheers mate
Cheers.
http://www.brandsport.com/howdoifirilu.html
Old Apr 3, 2008 | 11:46 AM
Originally Posted by ZedStyle
Cheers mate, but I still don't get it LOL. Does that mean I can't use my existing MB bolts?
Old Apr 3, 2008 | 11:57 AM
ZedStyle's Avatar
Youngtimer
the hole in the wheel is wider than your lug bolt
Old Apr 3, 2008 | 03:22 PM
YNVDIZW124's Avatar
lots of cars
Ok, let me explain a little better. The audi wheel has a smaller center bore which needs to be bored out to 66.59 from I think 57.1. You need to see if there is 10mm of meat on the back of the wheel that came be bored in 4-5mm. Once you do that the wheel is going to sit on the hub properly. Now about the lug bolts, you will need conical lug bolts (right) like showned in the picture below. Mercedes wheels use a ball seat ( left) and are 12mmx1.5. The next problem is that audi wheels have larger lug bolt holes which are 14mm. That's a 2mm difference from the lug bolts you need. You can get a plastic sleeve to center the bolt on the wheel and you shouldn't have any problems. The sleeve has to be 2mm in thickness and about 3mm wide.
Old Apr 3, 2008 | 06:27 PM
Cheers to both of ya!
Think I'm dropping the idea then. Far too much work. I was thinking about 18" A8s..
Now I'll go have a look at BBS 15" deep dishes.. If I can't find any, I'm just gona go with some Japanese rims..
Old Apr 3, 2008 | 07:17 PM
berti_00's Avatar
2016 Cls63s AMG
jeffry did you yet take your spring pads off?
Old Apr 4, 2008 | 10:43 PM
Yeh I did mate sup?
Old Apr 4, 2008 | 10:48 PM
berti_00's Avatar
2016 Cls63s AMG
Yeh I did mate sup?
ohh cool well hows the ride and stuff and how much difference is from pad to no pad? and do you have anything under there or just metal metal contact
Old Apr 5, 2008 | 01:23 AM
Hmm.. Well, haven't been driving the car at all so I'm not sure how it rides. At least right after I got the pads off I didn't feel a difference as regards ride quality..
If you remember, I'm the high pressure hose guy. There's a high pressure hose on the top coil of my springs to somehow eliminate metal to metal contact. How long that lasts I don't know.
The height change was minimal but again, I didn't let the car settle. I'll have to cut the rear springs soon though.. Whatever gives me that extra 10mm I need..
Let me know if you need anything else. Cheers
Old Apr 9, 2008 | 01:07 AM
hellah fresh's Avatar
Was 89' 300E, Now 93' 500SEL
Yo! What the max wheel offset we can go on a 300e... say for example 18x8". I know 17x7.5" rims will fit i was just wondering how wide can we go to keep a clean look. 7.5-8.5" max?
Old Apr 9, 2008 | 06:01 AM
LOL before Zorro jumps on ya!
Depends what's "flush" to you mate.
This look flush to you at all?
Sorry don't really have decent pics
Old Apr 9, 2008 | 04:02 PM
Well... the rims im looking at are 18x8.5 or 19x8.5. But Really leaning towards the 18x8.5. Yes those wheels look flushed. Does not stick out. MY main goal is to lower the 300e with 18x8.5. What do ya think?
Old Apr 9, 2008 | 04:14 PM
ZorroAMG's Avatar
Enzo, my Benzo
try it and let us know...there is a thread stickied at the top, but what do we know?
Old Apr 9, 2008 | 05:57 PM
YNVDIZW124's Avatar
lots of cars
Zorro - You could have typed the answer if they fit in the same amount of time it took you to type that sentence.
Hellafresh - You can fit 18x9 with the right offset and rolled fenders.
Old Apr 9, 2008 | 06:13 PM
^^ Thanks! yeah zorro what NV said! lol Well i forgot to look at the stickies. The last time i logged on before yesterday was 11/17/07 till now. Oh well i found the rims and they are offering 19x8 and 19x9. But i emailed the guy asking if he could do all 4 rims 19X8. oh yes rolling of the fenders is a must!!
Old Apr 9, 2008 | 07:10 PM
ZorroAMG's Avatar
Enzo, my Benzo
I'm sure I could have but laziness bothers me.
