Potentiometer removed -- Shud the car run alot worse?
Old May 25, 2008 | 09:18 PM
ps2cho's Avatar
E
Airflow Potentiometer removed -- Shud the car run alot worse?
I disconnected my potentiometer today trying to route down my misfire and with it removed, there was almost no difference to my misfire at all.
Could I have found the suspect possibly?
I intend to check out the MAS next week.
Any thoughts?
Robert
Old May 25, 2008 | 09:40 PM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
Any thoughts?
Robert
Pardon my ignorance - Which potentiometer did you remove?
Old May 25, 2008 | 10:10 PM
ps2cho's Avatar
E
This one That is with the plug removed, of course.
Attached below the Fuel Disty.
Sorry, should have been more clear.
Old May 26, 2008 | 03:07 AM
California260E's Avatar
1987 260E
Im curious... with your rough idle problem have you replaced the Overload Protection Relay?
Old May 26, 2008 | 10:02 PM
shdoug's Avatar
Did you try driving it with that disconnected to see if it makes a difference? Your check engine light is cleared now isn't it?
Old May 26, 2008 | 10:41 PM
ps2cho's Avatar
E
It made almost no difference...just a little shuddering when I came to a stop for a few seconds before the rpms were increased to compensate I assume.
Yes it was one of the 1st things I did that resolved a stalling issue.
