Common Fuel Issues?
Old Jun 4, 2008 | 11:42 PM
odelay17's Avatar
95 Eclipse GST, 93 MB 300e
Common Fuel Issues?
I only state this claiming it to be a common fuel issue because my 91 had it and now does my 93.
I figured i would take a shot here if there was an experienced member who would be able to nail it for me, thought he symptoms are a bit general.
The car will crank and crank, but no fuel is getting to the injectors.
What are common points of failure in the 300e fuel system?
Thanks!
Old Jun 5, 2008 | 01:13 AM
ohlord's Avatar
Fuel pump relay
fuel pump,fuel filter,fuel pressure regulator.
Have you run diagnostics?Checked voltage to the pump with key on?
Can you hear the fuel pump running?Check that fuel is getting to the injectors.
ohlord
