was a bit skeptical but wow
quick fix stuff i know but they will get me by until i pick up one more job. oh and i have seen way better mpg im now going around 280 miles on one tank.
Apparently your check engine light is on too, but thats just a matter of finding a smogger who doesnt care about the light as long as you pass the sniffer. Which is almost any of them.
Ohh yeah I would avoid any liquid sealants, those are just temporary fixes.
Think about it if you pour any of these liquids into your tranny, motor, or radiator to seal leaks what do you think that gunk is doing to the rest of your internal parts?
~Cali
ohlord
"GOT CODES?"
ohlord
"GOT CODES?"
i burn some oil and have to add oil every 3 months and i never have seen my car smoke
oh and i am one of the people on here who dose not care about paying for gas. and last i have no O2 on my car
. Just Google it and read up on it, a gallon costs around $10 USD, dump it in when your just about at reserve, take a spirited drive, and watch the guys face when you pull some nice smog numbers.
We need to learn to ask the most obvious questions first with you Rio. Go buy a 02 sensor. (3-wire mustang 02 is a simple and cheap "Cut and splice" DIY at around $40) Search it.
ohlord
"GOT CODES?"
Im looking at my results at this very moment. Doing nothing but changing the cat brought my HC levels from 235 and 239, to 104 and 80.
It brought my NO levels from a staggering 2237 and 2027 to a mere 595 and 167. And my O2 levels from 0.8 and 0.7 to 0.4 and 0.2.
You should definitely look into making your own code reader Rio. Even if you dont have the money to fix the actual problems you will at very least know what they are, and can possibly map out some type of plan to get stuff done little by little.
hay rivcal4life i have a question my car i have 3 cats 2 pre cats and one main cat.
the main cat is welded on along with the 2 pre cats witch bolt on at my headers
witch one would i replace it is all one unit on my car.
my auto teacher tells me to replace my spark plug wires there fu(ked if you ask me i mean just bad burn marks all over them and they feel limp and loose
and last to have my timing looked at out of it all im going with the cheap stuff 1st timing and wires if that dont help then i call and try to get my car fixed for free from the program
also in California it is illegal and you will pay a big find or jail time
this is a quote i got from a web site with alot of research put in to this
((From a chemists point of view, sounds fishy... I know enough about engine combustion to know that if you want to ever run "clean" fuels (ie. methanol or ethanol), you need to re-adjust multiple engine components to get it running right. If you were to add methanol to the fuel, it would NOT run cleaner. In fact, it may cause you to fail the emissions test even if you would have passed! Funny side note here: a friend of mine had an old Olds with over 300K kilometers on it and needed to pass emissions. So he took a bottle of octane from the lab and added it to his tank. Needless to say, he barely made it to the shop and luckily, didn't fail. Some guys will try anything.)))
93 Octane=FAIL 1/4 Ratio of methanol=Pass (With flying colors)
...btw in CT there were no chemists in the garage I went to.....damn places cutting corners these days!
However, don't do it. I'm thinking about this and you'll find a way to blow your car up and I would rather you spend the $200-$350 for both CATs and fix the problem. FYI I found a new center CAT for non-calif cars on ebay for about $280 shipped so you might want to look.
Glad to hear that the wires made a world of difference, don't let it lead to careless driving though. Careful Rio!
Good to hear you got rid of your misfire Rio, I had a set of ignition wires that were arcing that caused my car to run rough. Thankfully, that was taken care of. Then, my thermostat went, then either my cat or muffler has now gone. Also, my odometer has stopped working. But whatever, still like the car
my car is like my zen. working on it makes me happy. and if my car runs better from what i do i feel more confident like i can take on a bigger task.
not a bad car it just needs TLC
