what Rims to Use for 1992 300e
2000 e430( w210),1979 240D (w123), 1992 300e(w124), 1990 mitsubishi galant VR4
I have a 92 300e w124 body, will a stock w210 e320 wagon size 16 rims & a 2001 Clk size 16 rims fit?
what size of lugs do i have to use ( or i can still use my OEM lugs)
do i need a spacer ?
Cheers!!!!!
Cheers!!!!!
Last edited by roach_juts; 06-30-2008 at 07:38 PM. Reason: did not tell what car i have
lots of cars
Polished CLK rims fit fine and w210 should fit just check that the offset is not more than 44mm. Lugs could change between rims but maybe you will need to grind down the ones on the rear so they won't hit your e-brake. I've had CLK, SLK, C-Class, and E-class 16" factory rims on my car and they fit fine all 16x7 or 7.5. You should use the Search on the forums to get more info.
Set of 20
in any size you need.
http://www.radusadirect.com/
$43
or discount tire stores has lugs.
ohlord![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
"GOT CODES?"
$43
ohlord
"GOT CODES?"
