No A/C
Old Jul 4, 2008 | 08:18 PM
California260E's Avatar
1987 260E
No A/C
On my 260E the A/C isn't working right. The pressure in the system is OK. The low pressure hose feels hot. And it looks almost like the Compressor clutch is always engaged. Where do I go now?
Oh, btw I changed the Receiver/Drier.
Old Jul 5, 2008 | 12:28 AM
neanderthal's Avatar
my AC works.
my fan doesnt
Old Jul 5, 2008 | 03:07 AM
landspeed124's Avatar
1987 260E
Is the aux fan in front turning on? Is the blower motor working properly?
Old Jul 5, 2008 | 03:42 AM
1987 260E
yep all fans running. the temperature from the IP vents arent very cold.
Old Jul 5, 2008 | 07:52 PM
CDP's Avatar
CDP
W124's
Blower motor probably has gone bad or your A/C Compressor clutch is stuck.
Old Jul 5, 2008 | 11:34 PM
shdoug's Avatar
1995 E320 SE, 162,000 Miles (Sold) 2007 CLK350 Cabriolet 2014 ML550
Something's not right. What are the low and high side pressures with the clutch engaged? The suction line cannot be hot if the compressor is running. If it is, your compressor has shelled out by the time you're reading this. When you say receiver/dryer, you mean the high-side device which contains the sight glass, right? Once I know the pressures, or at least the suction pressure, I can probably troubleshoot your system.
Old Jul 6, 2008 | 03:47 PM
1987 260E
Yes its the part with the sight glass. The gage on the tool said that the low pressure side was 42 psi. I am unable to read the High pressure end because I only have a low pressure gauge.
Old Jul 6, 2008 | 11:23 PM
CharlestonN's Avatar
03' CL55 AMG
Can you tell if the compressor engages?
Old Jul 7, 2008 | 02:32 AM
1987 260E
Yes it appears to engage but not cycle on and off.
Old Jul 7, 2008 | 08:41 AM
Rio Z Lander's Avatar
i now drive a ford p71 i also own a 1988 ford f150 lariat
after the last rain fall here where i live i have not had heat or air but my a/c pop on and it was very cold air coming in the car but then went away the next day
heat comes in my car when it is moving ?????? bot not when it is stopped ?????
same when it a/c was on only when the car moved did i feel it
what is going on i wish i knew
Old Jul 12, 2008 | 05:49 PM
1987 260E
I think my problem solved it self. I used the car today actually taking it to get the pressure readings and the cold air was coming out great. I wonder why it works all of a sudden?
Old Jul 24, 2008 | 10:37 AM
Smokiesman's Avatar
93 300SE Rauch "Smoke"
Possible that the expansion valve was stuck or clogged with debris!
Smokie
