1989 300E
A double contacted bulb made my car go solid turn signal.
The bulbs are original except for the left front turn light. I will check all of them later for any connection issues and contact type.
Thanks for the ideas!
Is there a simple turn signal relay (flasher unit) that can be replaced? Behind the instrument cluster? Read somewhere maybe the hazard switch could be defective and causing the problem. More ideas?
I took out the combination relay located next to the fuse block under the hood. Hmmmm..........something was rattling inside the sealed relay! Not a good sign! Ordered a replacement relay from from Autohauz. Hope this was the problem!
