W 124 front bumper repair/replace?
Old Jul 15, 2008 | 07:04 PM
golfinator's Avatar
95 E320, 2002 E430
My 95 E320 front bumper was backed into. The left side of the bumper's middle section is cracked from top to bottom (4-6") and the end is popped away from the piece behind it. The insurance company's "preferred vendor's" estimate shows replacing the impact cushion for $22.50 and using flex additive, paint and clear coat to overhaul, repair and refinish the bumper. Is this a typical fix or should I insist on a new bumper?
Old Jul 15, 2008 | 08:05 PM
Bigpete123's Avatar
1990 300ce
I'd have to see a picture to understand what you're saying, but it sounds to me like you just need a new impact strip and some paint...
Old Jul 15, 2008 | 10:46 PM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Parts, labor and paint should be around $500 which would include a new bumper assembly and impact strip....
Not sure how good of a repair you could do on the bumper if it's split.
Usually cheaper to replace then repair as you'll have a few manhours to repair and sand the bumper prior to painting.
Old Jul 15, 2008 | 10:54 PM
golfinator's Avatar
95 E320, 2002 E430
Don't know if you can make these out.
Attached Thumbnails W 124 front bumper repair/replace?-e320-bumper.jpg   W 124 front bumper repair/replace?-e320-bumper-2.jpg
Old Jul 15, 2008 | 11:00 PM
golfinator's Avatar
95 E320, 2002 E430
Thanks RBYCC. Can you tell me what parts are typically in the bumper assembly. I assume the impact strip is the part that's cracked.
Old Jul 18, 2008 | 08:25 AM
golfinator's Avatar
95 E320, 2002 E430
Aftermarket impact strip is $165 + $50 to paint.
