300TE Help? Weird problems.
10 years ago someone dumped sugar/salt in the engine, entire fuel system was flown in from Germany and replace, the engine was sandblasted but was left with 2 cylinders with slightly low compression.
2 years ago the car barely passed emissions due to high hydrocarbon count. The car was run on the interstate for a bit and passed with .001 to spare.
1 year (about 1500? miles ago at most) the alternator was replaced. At the same time the mechanic said that it might need a new fuel pump (I think I cannot remember what might need to be replaced but it would cost 1-2k$ for parts and labor combined). Although a few years ago I swear the fuel pump had been replaced.
4 months (200-400 miles ago) distributor cap was replaced with the mechanic noting major carbon deposits.
1 month ago after sitting for 3-4 weeks while I was in Africa the car leaked a small puddle of fuel (and the normal transmission fluid seepage as well).
There is no oil evident in the coolant.
For the past few months the car has been having a new problem. The car will start perfectly and run fine until it is shut off for a short amount of time. For example if you went grocery shopping or a beer run. When you go to start the car cranks but will not start. On occasion after a few false starts the car catches and if it doesnt die, will run rather rough, stalling if the engine rpm falls below 800-700rpm. (it normally idles around 500). If the car is left for a few hours there are no problems at all. The cars exhaust has a strong smell of unburnt fuel. If the rpm goes over 2500-3000 a big cloud of black soot? comes out the back. (Think ww2 destroyer laying a smoke screen).
So here are my questions. Is it worth fixing on a car this old? Would my family have a chance at selling it? Should they forget it all and donate the car to charity? I have a younger brother who is learning to drive and we were thinking of letting him use this car for his first few accidents.
and I have no intentions of selling.Have you checked under the hood at the diagnostic port flash/code light to see if anything pops up? Could be a simple as a fuel pump relay or O2 sensor.
Thanks again!
