'95 E300D Questions
1.) I don't have any input other than doing a search of the forum.
2.) MBUSA does have the manuals on cd:
3.) This is a common problem. The parts to fix are inexpensive but getting the back off the seat is not real easy. A search will turn up a lot of information.
Do you hear any motor action for the head rests? The common problem is a plastic gear rack that breaks. When you remove the rear panel for the seat (hardest part of the job), the problem should be obvious. The part should cost $20-$30.
Thank you for the information. Unfortunately, the workshop manual CD-ROM for Model Year 1995 E300D isdiscontinued. If you wish, you may check our service and repair technicalwebsite at www.STARTEKINFO.com or www.classictechlit.mbusa.com to furtherpursue your inquiry. The opportunity to respond is our pleasure. Sincerely, Patricia R.Mercedes-Benz USA, LLC.
Waiting to hear back from www.classictechlit.mbusa.com on the manual.
One seat makes noise the other does not. When I get the manual I will take them apart.
I guess I will go look under the back seat for the control box.
Thanks for the info.
The only problems I had were in the beginning due to the wiring harness that needed to be replaced, at that time I put in new glow plugs and glow plug relay and she's run flawlessly for the last 80K miles - can't get less than 32 mpg on the freeway with a million dollar ride.
