Cold start valve: Testing question
Old Nov 3, 2008 | 05:00 PM
Ron in SC's Avatar
99 ML 320, 97 Porsche 993 C2S, 92 300E
Question Cold start valve: Testing question
Can the cold start valve be tested when it's not installed in car?
I know it is getting voltage when engine is cranked, since I tested the connector.
I supplied voltage to CSV when it was out of car since I thought I might hear it click or something. I heard nothing.
Any suggestions?
Old Nov 3, 2008 | 09:51 PM
RBYCC's Avatar
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
Any suggestions?
Ambient temp in SC hasn't been low enough for the CSV to come into the starting circuit.
Put it in your refrigerator and get it down to about 40F.
You should get voltage through it, but it only functions for a short time in order to start under a cold ambient.
Old Nov 4, 2008 | 07:32 AM
Ron in SC's Avatar
[QUOTE=RBYCC;3147876]Ambient temp in SC hasn't been low enough for the CSV to come into the starting circuit.QUOTE]
Ok, that makes sense.
I'm trying to diagnosis a very hard to start situation. I've ruled out all the sensors in the head.
I'm trying to test the ISV, I put meter to connector and cranked engine. No voltage to connector. Maybe that is the problem.
Edited:
I just tested the ICV and when I supply 12 volts to it I hear it working.
Problem is that when I crank starter I do not getting any voltage going to ICV connector.
I have tested all sensor in the head and they are within ohm specs for a cold engine.
When I test connector wires with ohm meter I get 157K ohms.
So what next? Do I have a broken wire somewhere?
Old Nov 4, 2008 | 08:53 AM
RBYCC's Avatar
[QUOTE=Ron in SC;3148322]
Edited:
Have you looked at the OVP and fuel pump relays?
The OVP is a major junction point for the signals that will start the engine.
Could be something as simple as a blown OVP fuse or a weak relay.
Old Nov 4, 2008 | 09:10 AM
Ron in SC's Avatar
[QUOTE=RBYCC;3148374]
I had previouly swapped out the MAS relay and the OVP from my other 1992 300. No difference.
Shouldn't I be getting power to the ICV when I crank the engine?
Old Nov 4, 2008 | 01:54 PM
RBYCC's Avatar
[QUOTE=Ron in SC;3148393]
ICV = Idle control valve ?
M103-12V or M104-24V engine ?
M103 uses an idle control valve with the KE injection, I don't believe M104 with the HFM injection has an idle control but uses an electronic throttle actuator.
Old Nov 4, 2008 | 05:42 PM
Ron in SC's Avatar
Yes
M103-12 volt
Old Nov 5, 2008 | 07:54 AM
RBYCC's Avatar
Yes
M103-12 volt
Just wanted to confirm that you have the M103-12 valve sohc engine.
The idle speed control valve is wired between the OVP and the KE control unit.
If the OVP isn't functioning properly you will not see voltage to the ICV.
More importantly the ICV will not cause hard starting, just an erratic idle after start.
We can probably rule out the CSV as it is a long shot.
Does the car just crank a long time before starting or not start at all ?
If it does start is the idle stable or does it hunt.
Are the fuel pumps working ?
No start is usually the fuel pumps, OVP, fuel pump relay, sensor plate or temp sensor.
