seat back removal
Old Nov 5, 2008 | 10:58 AM
jdr01's Avatar
82 300D, 95 E300D
seat back removal
OK, I am stumped again. I need to remove the plastic cover on the rear of the front seat. I want to get to the head restraint adjusting rail. The two screws at the bottom are removed but nothing seems to give. I don't want to force anything and break it. Any trick to get this off?
Old Nov 5, 2008 | 12:40 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
There's no real good way. It takes some force and some guts to get it apart, especially for the first time. You think you'll break it, but it'll come apart eventually. Try working from one of the bottom corners.
Old Nov 5, 2008 | 01:53 PM
jdr01's Avatar
82 300D, 95 E300D
Separate at the seam or pull out toward the rear?
Old Nov 5, 2008 | 01:59 PM
Kestas's Avatar
Pull back cover toward the rear. You may need to get it started with a screwdriver. The cross section of this joint is a complicated "S" pattern that I can't recall from memory.
Old Nov 5, 2008 | 02:05 PM
jdr01's Avatar
82 300D, 95 E300D
I will try again. It looked like something would snap when I tried that
Old Nov 5, 2008 | 02:42 PM
jdr01's Avatar
82 300D, 95 E300D
OK it's off and nothing broke. After I got it started I could see that the back panel has to stay and the side material stretches toward the rear releasing the interlock. The problem with my headrest is, the gear assembly is missing. The previous owner must have removed it. Thanks again,
