--VIP rims on w124 rides--?? is it doable!!!
Old 12-09-2008, 07:43 PM
  #126
Bigpete123's Avatar
1990 300ce
I completely agree with you guys. but ultimately it comes down to personal opinions... some people like things that I don't like. But if it makes them happy, I shouldn't give a ****.
Old 12-09-2008, 08:21 PM
  #127
berti_00's Avatar
2016 Cls63s AMG
keep it classy and tasteful as Will Ferrell Keep it classy San Diego lol
Old 12-09-2008, 10:22 PM
  #128
YNVDIZW124's Avatar
lots of cars
Well, I always wanted to have an S-500 straight sittin on twenties tv in the dash pimpin hoes gettin money. I guess i'm too "ghetto" to own a mercedes. Whatever, moving on....
Old 12-09-2008, 10:26 PM
  #129
appatula's Avatar
95' AMG SeeThreeSix
Originally Posted by ZorroAMG
You guys DO realize that VIP is only called that because that's how they spell the word in Japanese to english translation. It's actually a word pronounced bippu.
It has nothing to do with actual VIP....although gangsta yakuza started the trend...
Again, I'd hardly consider gangsters VIP.
I didn't know that actually , however, I did assume that "VIP" had nothing to do with the common English abbreviation nonetheless it really is, unintentionally still kind of a cheesy name.
I think were basically all on the same page here, I was feeling like the odd one out for a second there
Old 12-09-2008, 10:28 PM
  #130
appatula's Avatar
95' AMG SeeThreeSix
Above all I really hope your not pimpin' hoes ....reminds me of taxi driver
Old 12-10-2008, 01:18 PM
  #131
ozopera's Avatar
97 E420, e320 Wagon, e38
BTW - I just confirmed today that 19x8.5 +42 does not fit the front. It hits the inner wheel lip. Also, 19x8.5 +42 fits rear without any spacer and still has about 10mm-15mm left from the shock. I would live it like so the wheel can camber in when you have weight in the trunk or passengers.
My carlsson 19x8.5 +40 fit like a glove on my wagon with 235/35/19 tires (no spacer) and still have some space between the suspension and the back wheels. If you running this size on the back it will fit too, but i am running 5mm spacer to make the wheels look flush with rear fender.
For our car W124 I'm sure you can have 19x10 +45 for rear wheels without any spacer. I think the white wagon(obetski) running 19x10 +45 on his car.
Both our cars have the same carlsson rims expect mine is not staggerd.
here is the picture just to see how the front wheels fit. There is no rubbing at all! And on the back there was more than 10mm gap between my tires and rear fender lip, I want my wheels to sit flush with the fender, so thats why I add 5mm spacer to make the wheel sit flusher with the Fender. (FYI i rolled my real fender)
Old 12-10-2008, 01:25 PM
  #132
Bigpete123's Avatar
1990 300ce
wow, that wagon is sexy.
Old 12-10-2008, 03:40 PM
  #133
YNVDIZW124's Avatar
lots of cars
On the front - Yes, I agree they fit with a +40 offset perfectly. I'm running 18x8.5 with a 39mm offset and no rubbing at all. When you go to +42 it really depends on the wheel lip but it's just way to close to the suspension. There is only about 1-3mm of space between the wheel and the strut on a +42 wheel. You need some space when the wheel turns in so it won't be hit the strut.
On the rear - The problem is not making the wheel fit. You can fit the 19x10 with the right offset. I would say +30 or even +35 would be ok but anything higher might rub the shock. The problem for such a wide wheel and camber is that it would hit the inner fender under load or on bumps. Try it and i guess let me know what happened. 19x10 +45 has 7.2" of backspace and i don't know if we have that much space on the rear.
I don't know what the hell i just said there but let me correct it.
I would not run that high of an offset because it might hit the the top of the inner fender. Specially when it's under load or when you have passengers sitting in the back.
I don't like giving advice on aggressive fitments that might not fit our cars. I don't want to be liable for telling someone 19x10 fits and then they don't fit or their cars get messed up. I'll try aggressive fitments on my car any day and let you guys know
Old 12-10-2008, 05:10 PM
  #134
V9.
V9.'s Avatar
W124
Ozopera what kind of suspension do you have on the TE....details details!
Old 12-11-2008, 01:31 PM
  #135
ozopera's Avatar
I am not sure, how familiar are you with the front suspension of W124. The inner side of the wheels will never hit the strut even you only have 1-3mm space. It doesn't matter how hard you turn you steering left or right that inner wheels will never hit the strut unless you have a bend rims.
See this picture (this is from w124 AMG suspension conversion), you should know what i mean by looking at this picture.
For sue 19x10 +30 and +35 Is not OK for W124,It will stick out like an 1" (will hit your outer fender for sure. Why you say +30 is OK? Did you try once??
Here is the picture of my car when I was running 18x10 +30 (yes its 18"...19" will be worse)
Here is the pic, 18x10 +30 on my 95'E320(sold already)
Here is the gap between inner wheels and the strut mount I measured 22mm gap, when i run 18x10 +30. That mean if I have 18x10 +45 that would be better fit.
Attached Thumbnails --VIP rims on w124 rides--?? is it doable!!!-w124amg-front.jpg
Old 12-11-2008, 02:35 PM
  #136
berti_00's Avatar
2016 Cls63s AMG
i have now faith that 9.5 will fit no problem lol but the thing is that mine is much lowred than the pic above but than again i have hella camber soo i say it should fit
Old 12-11-2008, 08:43 PM
  #137
YNVDIZW124's Avatar
lots of cars
I will only tell you only from personal experience. Like I said, 19x8.5 +42 hits the strut on a full turn. Our struts have a notch i guess to clear the wheel. I'm pretty familiar with the suspension and how it turns but i don't know what to tell you.
This is where it hits on my car..
I'm saying "it fits" but i didn't say you can drive like that everyday. There are too many factors when you are trying to fit wide wheels on our cars. What fits on my car might not fit yours. I'm running -2.9 camber on my car and i know the wheels rub on the inner fender because i've tried it. If you search the threads for AndrewNY we had this discussion before. He was running 19x11 i think?. I'm sure with a stretch tire and lots of fender rolling a 19x10 +35 would fit. I'm not saying it will look good or even a good idea but it fits right?. Btw - the TE might have more room because of the rear hydraulic suspension.
What i said before..
Point is would 19x8.5 +42 and 19x9.5 +38 fit? yes, with a 3mm or 5mm spacer in the front. Rear should be fine. Let's not start a pissing contest and just share the info on our cars that might help someone else.
Old 12-19-2008, 08:56 PM
  #138
1995E320Cab's Avatar
2003 CL600 2005 745Li
OK guys I have a set of AMG (OZ) 3 peice forged wheels that are 17x8.5 ET18 and 17x10 ET17. I want to make these fit my 95 E320 Cab, I have been told that I can grind 10mm off the back side of the hub. That would put me at 17x8.5 ET28 and 17x10 ET27 BUT after reading these posts I'm not sure that it will work. Here are the wheels and here they are on another E320 Cab (not mine) What do you guys think how can I make them fit ????
Attached Thumbnails --VIP rims on w124 rides--?? is it doable!!!-e320cabshop.jpg   --VIP rims on w124 rides--?? is it doable!!!-e320cabslammed3.jpg   --VIP rims on w124 rides--?? is it doable!!!-e320cabslammed.jpg
Old 12-19-2008, 09:32 PM
  #139
berti_00's Avatar
2016 Cls63s AMG
damm those wheels would look sooo aggressive on my caR
Old 12-19-2008, 09:42 PM
  #140
Heres another shot of the type of wheels I have, as I said the BIG question is HOW to make them fit.
Attached Thumbnails --VIP rims on w124 rides--?? is it doable!!!-amgmultipcset.jpg
Old 12-19-2008, 10:04 PM
  #141
berti_00's Avatar
2016 Cls63s AMG
the only way to see is try them on
Old 12-19-2008, 10:13 PM
  #142
Well I know that they will not work like they are now, so I just to see how much to get shaved off the back.
Old 12-20-2008, 12:44 AM
  #143
YNVDIZW124's Avatar
lots of cars
Please don't do that to those wheels and don't ever follow that advice, EVER!!! You can shave off 2-3mm but 10+ is insane.
So you have 3pc wheels, Think about it? you can take them a part and have new barrels made or if you can find other 3pc oz wheels they should interchange. Get a new smaller outer lip and a wider inner barrel and that should change the offset to whatever you want. I been around wheels a lot because that's something i do on the side. I've had a some oz, bbs, ssr, and rays wheels before so i've been around 3pc and 2pc wheels.
Old 12-20-2008, 01:04 AM
  #144
I was thinking some of the same, thats why I posted to get others input. I was told that the Black Cab I posted a photos of shaved 10mm off the center to get the wheels to work. Just doing research right now, thanks for the input.
Old 12-20-2008, 03:29 PM
  #145
Well it looks like these wheels are a bit to much for my car....
The goods news is they are great wheels with no cracks......
Maybe I can trade them for a set that will fit my car ???
Anyone want to trade ?
Old 11-15-2010, 02:50 PM
  #146
ruslan98270's Avatar
300e amg
yes its doable!
Speedline 3pc Wheels
F: 18×10 et+20 225/40/18
R: 18×12 et+20 245/40/18
here is pic video: http://www.youtube.com/watch?v=HsKDB...layer_embedded
Old 11-15-2010, 03:37 PM
  #147
300e amg
pay some guy who know whats he's doing and he will roll the fender lip, should be about 50-80$ a corner, put 215 on fronts and 235 on back and it will fit really nice
Old 11-16-2010, 02:12 PM
  #148
BlackStar Stig's Avatar
W124 230E 1990
18" Monoblocks, 8,5" at the front and 9,5" at the rear. Offset is 35 all around. Tires: 215/40-18 infront and 225/40-18 at the rear. Car lowered aprox 40mm. Not rolled any fenders, but did notice some rubbing from the rear fenders when the car was loaded with people.
Old 11-16-2010, 03:03 PM
  #149
300e amg
needs to go lower ^^^
Old 11-16-2010, 03:21 PM
  #150
W124 230E 1990
Yes, I know. And it will as soon as I get all my fenders rolled.
Quick Reply: --VIP rims on w124 rides--?? is it doable!!!
