Rear Spring Pads
Old Nov 17, 2008 | 05:55 PM
ronald7410's Avatar
1992 300CE
Rear Spring Pads
I purchased these rear pads from buymbparts.com. They Sent me the wrong ones and they are too big to sit into the seat. The original ones are 4" in diameter while the new ones are 4.5" in diameter. They arent willing to replace or refund me so i am stuck w them.
Should i cut the pad and slice off a chunk to make them smaller diameter? Bad side about this is that the pad will have slit and possible slip out while im driving?
Or should i shave around the edges to force the fit into its seat? Where the cup shape no longer remains and i only have the rubber pad that sits atop the spring?
Or run w/out spring pads. Maybe lube up the seats and spring before reinstalling the springs?
Im going from a #4 Pad to a #1 or possible none.
Lmk what you guys recommend
Old Nov 17, 2008 | 10:55 PM
whipplem104's Avatar
1990 300ce supercharged and intercooled
I have run no pad before. I had no problems. I would not use the wrong diameter ones though. They do not cost very much, just get the correct ones.
They may have sent you the fronts.
Old Nov 18, 2008 | 12:10 AM
ZedStyle's Avatar
Youngtimer
there are a few of us on here now with no spring pads and no issues so far.
Old Nov 18, 2008 | 01:32 AM
V9.'s Avatar
V9.
W124
Hey Ronald...I'm changing out my rear pads too and need to rent your compressor!! Why don't we have a spring pad party in socal and do it at the same time...rental fees still apply
btw I just got done lowering my 911...got stiffer torsion bars and had to re-index them and then corner balance the car....its a ton of work...coil springs are a lot easier to deal with.
Old Nov 20, 2008 | 02:57 AM
ronald7410's Avatar
1992 300CE
Hey v9,
Pmed you.
OK guys, im thinking to take the leap into no spring pads. Hopefully all goes well. you guys didnt lube up the spring before seating it?
Old Nov 20, 2008 | 03:02 AM
ronald7410's Avatar
1992 300CE
Well i kinda have to work with what i have, i dont really want to spend another 13 bucks for another set.
But if you guys dont understand what i meant in my first post. Basically cutting a slice of the pad so it would fit properly into its seat. or just cutting the slicing the edges so it would fit also. Lmk what you guys think would work best.
If none seem right, no pads it is.
Old Nov 23, 2008 | 11:56 PM
ronald7410's Avatar
1992 300CE
took the big leap. added compressor lubricant to the top of the springs just for safety.
