e420 sportline/euro suspension
1994 E420
has anybody seen this setup? or driven a car with this setup?
what is the major difference between this setup and the h&r/eibach/vog suspensions
I am thinking about buying the springs from Rusty and installing them on my e420 with bilstein sport struts and shocks...good idea?....
i had h&r but the ride was way too hard for me.
any input or suggestions are welcome.
i am not concerned about slamming it (actually i do not want it dropped too low)
just want less body roll and more stablility.
thanks in advance
thanks in advance
400E
No such thing as an E420 Sportline from the factory. But you could do quite a bit with aftermarket parts. Shocks and/or springs would be the place to start. Both HDs and Sports are available for the car, Sports designed for lowered springs. See page 2 below. A true Sportline has quicker ratio steering - never heard of anyone swapping that out.
http://www.bilstein.com/305bilsteinapplicationguide.pdf
1994 E420
The E420 Sportline was only offered in Europe. It included the normal Sportline equipment with notable changes in the steering box and front/rear suspension.
I am only looking for the suspension components which include
2 x 124 321 42 04 front coil spring
2 x 124 324 28 04 rear coil spring
I already have the front and rear 500e anti-sway bars
i am not looking to adjust the steering or replace the steering box (unless of course that part is available)
1994 E420
1995 E 420
i think the subframe bushing are also different too!and that could stiff up ur car a little more and give u what ur looking for as u already have the 500 front and rear sway bar.. care to share experiences on the 2.82 rear end?? how many MPG are u getting if u don't mind me asking! have a good day!
1994 E420
I will look into the subframe bushings as well
As for the 2.82 differential...wow...just wow
the drive is way more amazing..the transmission shifts better...the rpms are always in the optimal 2000-3000 area
0-60 time has been cut down by maybe 1-1.5 secs
60-100 is much faster
i hit about 125 mph at 4200 rpm so the autobahn speeds are still there
as for gas mileage
if i drive normally..i get 21 mpg combined
if i drive like a mad man...i get 16-17 mpg combined
too bad this transmission only has 4 gears
with a 5th...the gas mileage would be much greater..
as for gas mileage
400E
1994 E420
(I highly doubt they had a special steering box for this model though)
124 321 42 04 - Front 400E/e420 sportline spring
124 324 28 04 - Rear w124 sportline spring (all models)
rusty has both of these springs in stock (if anyone else is interested)
these numbers differ from normal 400e/E420 part numbers
i have a pdf that has all the part numbers
i will post it later.
1994 E420
here is the pdf that I have
i uploaded it to my server
http://www.blueboxpc.com/124_coil_spring_specs.pdf
16 E350 wagon, 94 AMG, sold -95 E320 Sportline wagon & 94 E420 & 95 E320 coupe & 92 190 16v
I just did the Sportline conversion on my 95 E320 Wagon. It was a lot of work and almost all the techs tried to charge for a lot of overlapping labor, so hammer them on the prices. The book says 6+ hours to change the rear swaybar alone!
I'd recommend the Sportline struts also as it makes for a very fine tuned system. Make sure you add up the points and get the right springs for the US car as the Euro version is lighter and the spring specs can be too low.
The Sportlines also have a different, shorter and stiffer, strut shaft buffers, about $19 each, get them now as they are free to install now but big money later!
There are Sportline front LCA bushings and rear subframe mounts too.
If you go to all the hassle don't forget the side badges
![bs](https://mbworld.org/forums/images/smilies/bs.gif)
1994 E420
thanks again for all the info!
i will probably be working on this in the next couple of months (its hard to do it all at once with no extra cash)
i am going to be doing much of the work myself so it will be a slow process
I can tell you the rear springs you selected
are for high option/U.S.A. sportline models.
124-323-06-44 --- Shaft buffer pics...
http://www.w124performance.com/image...p_buffers1.jpg
Also see below for lots of great info, pics, doc, etc...
http://www.w124performance.com/docs/mb/W124/
http://www.w124performance.com/images/
1995 E 420
Mercedes 300CE Sportline
thanks in advance
thanks in advance
well I'm from sweden.. and I've driven a 420e Sportline..
they are nice cars.
I read an old article recently and it said 2k for the sportline package. It may have been that they offered the E60 suspension as the sportline package, looking through my notes it cost around that.
I also show PN's light and heavy springs and shocks (including SLS) for the 400E. This is from a Dave generated list also.
-Mike
-Mike
1994 E420
thanks guys for all the info..so far this is what I am going to do
All prices are from Rusty at BuyMBParts.com
400E Front Sportline Springs: 124-321-42-04: $92 each (2)
400E Rear Heavy Sportline Springs: 124-324-36-04: $95 each (2)
Front Shaft Buffer: 124-323-06-44: $19 each (2)
Front Bilstein Sport Struts: $123 each (2)
Rear Bilstien Sport Shocks: $86 each (2)
Rear Sportline Subframe Bushing Kit:$86
Front Sportline CA Bushing Kit: (have to ask for price)
I already have the 500E sway bars ($169 for the front, $175 for the back)
Total Estimated Parts (including the ones I already have): $1325 <--yea..![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
All labor will be done in my garage (usually with alot of shouting and grunting...and occasional bleeding....occasional...)![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
hopefully when I get the money and the time, I will take pics of the progress
the suspension shouldnt be that bad considering I already had to drop the subframe for the differential...but with benz...who knows![nix](https://mbworld.org/forums/images/smilies/nixweiss.gif)
anyhoo...thats my rant for now...
let me know if i am missing anything...or if you guys would do something different...
thanks again.
thanks again.
300D, 500E, E420
As mentioned, yes there was a Sportline package offered on the 124.034 (400E / E420). It was largely based on components from the 124.036 (500E / E500). It used the 500E sway bars front & rear, and the 500E front struts, plus a faster ratio steering box, had Sportline badging, etc. It was never offered in the USA, though. Interesting side note... the European 400E/E420 came with a 2.65 differential, instead of that silly 2.24 that they shipped to the USA. ![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
The 500E was never, ever offered with a Sportline package. It was designed out of the box as a sport vehicle, with no "sport" upgrade available. It used most of the Sportline components available at the time, including the 4-seat interior, rear subframe bushings, special dampers, larger sway bars & wheels, etc. The only 2 items on a 500E which can be "upgraded" with factory components are the steering box (the 124.034 Sportline steering box is a faster ratio, but sadly is no longer available) and the front lower control arm bushings (the 500E came with standard/soft bushings, instead of the early Sportline hard bushings... late Sportlines reverted back to the soft, for unknown reasons.) Given the release dates of the original 124.036 and the first 300E Sportline package, it may be more correct to say the Sportline packages were based on the 500E, although some of the components (i.e., hard control arm bushings) were originally used on the 201.034/.035/.036 190E-16's back in the late 80's.
The 500E was offered with an AMG package, option code 957, which turned it into an E60 AMG. Sadly, this was not offered in the USA. The E60 AMG only has a larger engine, different springs & shocks, a larger front sway bar, and optional 17" wheels. That's it... the brakes, body, bumpers, interior, gearing, differential, etc were all the same.
![Cheers](https://mbworld.org/forums/images/smilies/cheers.gif)
