Whitest bulbs?
I gotta get me a set. What are the whitest bulbs available that would make mine like his?
I use these
http://cgi.ebay.com/ebaymotors/MTEC-...QQcmdZViewItem
The Mtec's blow the Silverstars away IMO
http://cgi.ebay.com/ebaymotors/_Car-...1%7C240%3A1318
For when I get these...
I use these
No HID lights in my euros! I also can't stand looking behind me and getting blinded by someone with this setup.
What about wattage or whatever? No chance I'll burn my housing or anything with these? I don't know a whole lot about bulbs. Should be plug n play right?
As for the high wattage, you won't damage the housing, just the plugs/wiring as Mr. 2Phast mentioned.
Where could I find the replacement plugs if they burn out? I have DEPO headlights so not sure if that makes any difference.
i think you should be okay on the wiring harnesses etc., the high and low beams both use the same gauge wiring, so running a ~high beam bulb wattage in the low beams will be okay. i used to run modded high beam bulbs in my low beams on my legend with no issues. when you start hitting 70-80W is when you'll definitely have issues...
So let me get this straight....
You put the MTEC Super White Xenon HID lights (the link 2PHAST provided) in your Depo Euros and got that result? I have a 1989 300E with Depot Euros and am thinking about doing the same thing! Looks good!
Did you do anything with the fog lights?
Will let you know how it compares to my silverstars. I'll probably swap one bulb and take a picture.
