Electrical demons
Try to reword the symptoms into different situations, and be more specific when you use the word light. It gets confusing when youre talking about brake lights, head lights, bulb-out light etc.
Example:
-When I press the brakes with the headlights off, the bulb-out light comes on.
-When I press the brakes with the headlights on, "----".
If you still have the old exposed-metal fuses, they should be updated as soon as you have the opportunity. When they blow, they dont always look blown. That can also explain your intermittent issues. You need to remove every fuse 1 by 1 and check the metal on those fuses to make sure it is entirely intact.
take out the carpet under the driver side and look around at the wire harness there was a recall back in the day from wires that would rub agents the metal and wear through. the dealers fix was only to wrap them in electrical tape.
I myself in my current car still have a short somewhere. I have never found it. made all my interior lights Including Dash not work. so I just stuck some lights in the dash and wired it to the sig lighter LOL
The recall was for the wiring harnesses under the passenger side metal footrest. The legs of the footrest could rub through the insulation on the wires and cause the engine to stall or the airbags to deploy. The fix was the reroute the wires and to wrap the feet of the metal footrest with felt tape. If any of the wires had damage the dealers replaced the whole affected wiring harness, they didn't just wrap tape around them.
