EHA valve readjustment
Old Jan 26, 2009 | 11:31 PM
ps2cho's Avatar
E
Is there a way to adjust it back to stock specs? I have fiddled with it and lost my original position.
I brought home one from the junkyard...but the car feels starved for fuel compared to mine...but buying a new one is very expensive...
I looked on the MB CD's but it only mentions replacement...not adjustment.
Anybody happen to know if its testable?
Old Sep 25, 2010 | 09:45 AM
anas2912's Avatar
Mercedes E 320 1994
the same Q
Any body knows?
Old Nov 5, 2010 | 08:07 AM
124 forlife's Avatar
*89 300 E -*91 300 TD -85 300SD *74 VW dune buggy
Never tought about. But good question tought.As profesional electrician it goes through my mind that EHA works same way as any light dimmer,but with some diference .While light dimmer gets electricity through as much you slide dimmer left or right,Eha opens and closes valve depending of an imput votage from computer where resistance of an spule inside the EHA is always very same. So my tought is that EHA is nothing more than electric valve and like that, one could be measured for "amount" of flow in agiven moment .
Old Nov 5, 2010 | 09:34 AM
whipplem104's Avatar
1990 300ce supercharged and intercooled
This is forbidden and you will be picked up by some strange men in a black sprinter van any minute.
I would unplug the eha and the o2 sensor. Check the voltage at the o2 sensor and make small adjustments until you reach 500mv. This should put you really close to correct as long as your fuel mixture was not far off when you started messing around.
Old Nov 5, 2010 | 10:17 AM
I guess the question was how to get back to EHA factory spec,not how to adjust a mixture,since ps2cho is not from yesterday.But thanks for respond and man in a black van.
Old Nov 9, 2010 | 12:45 PM
hineywineries's Avatar
It changes all the time
You're assumption is correct. Current changes affect amount of flow through the electro hydraulic actuator. Before EHA Bosch used a frequency valve to rgulate control pressure to the top od the piston in the fuel distributor. They got fid of the freq valve and replaced it with the EHA which regulates pressure in the lower chamber.
