E500 Custom Exhaust pics....
94' E500
ya that black one is a car i fixed up when i used to work at a custom shop in LA....my interior is gray of all things...ive owned two other 500E's in the past both with black interior and this one that i wanted in black came in grey...but its ok im going to do a full custom interior black with red with red stiching...on its way after i get the exterior and engine mods complete..
#32
Exhuast upgrades
An engine is simply an air pump. You want as much air in and out as quickly as possible. Forced cars respond dramatically to exhaust upgrade simply due to the fact that the additional air that is 'forced' in needs to exit at the same speed or greater to be efficient. Power is in your heads. Velocity of air flow is more important than volume though a great deal of both is fantastic. We here about volumetric efficiency which refers to this point.
With N/A cars, the size of your primary pipe (headers) is the most important part as the idea is for the set up to draw away (vaccum) from the exhaust port (try sucking water from a cup with a straw and then with 50mm pipe!!).
With my E500 all I will be doing is retaining the standard system including the cats (great from factory) and simply running 2 high flow stainless mufflers for great sound and some minor improvement in flow (performance). Unless you are increasing airflow to the manifold (cold air etc) don't increase primary pipe size - you won't lose HP but you will lose bottem end torque and torque wins races.
Exhausts are a simple science if you uinderstand the rest of the engine.
#33
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
The flow restriction is in the stock cat and you will see a HP gain by getting better flow rate.
#34
94' E500
Hopefully in the future i can manage some way to get more air in the box...I hate the fact that its so hard to get more cold air in that engine.....
#36
Turbo upgrade
Just wondering what is available as far as tuning software. I'm in Australia so very limited. I am planning on fitting a single turbo to my 211 E500 so will need to attend to AFR's, injector cycle, timing etc.
Anyone know of anything? Obviously it is around for aftermarket tuners (Brabus etc).
Drive safe.
Drive safe.
#37
Drive safe.![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Drive safe.
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Visit the W211 section and I'm sure you'll get many responses to your query
#38
1992 300CE
What was the size of your stock piping at its largest?
