Curious...
Old Jan 23, 2003 | 08:25 AM
Tank's Avatar
1992 Mercedes-Benz 300E 2.6L
Curious...
Okay, before I say anything, I'm going to say that I don't know ANYTHING about cars, except that when you push the right pedal down, the engine makes a noise, and the car moves =p
So, I have a 1992 300E 2.6L, 110k miles, and was curious about it's acceleration.. This thing accelerates REALLY slow, if I'm at a stopsign, then floor it, it will start off really slow, like if you're hardly pushing the petal down.. I wasn't sure if this was because it has a small engine, or because there is something preventing it from accelerating fast(a friend said something about a govener?)
Anyway, it just seemed pretty weird
Old Jan 24, 2003 | 11:10 AM
chupper's Avatar
A 1992 - can't remember again if that car had a first gear start....
ANyway tank, do this.
Before you leave your garage get out of the car and look down at where the pedal is. You'll see a little black circle thing past the pedal mounted there. You notice that when you push the pedal (gas pedal) the pedal will become close to hitting that black thing. If you truly "floor" the car then your pedal should not only touch that thing but make it "click."
When your car is off, push the accelerator pretty hard to make it click, you should hear it and feel it. People have different names for that thing, I just call it a power button. It usually drops you a gear and gets you goin real fast. I have an 89 with 300k miles and the car still pushes the passengers' bodies back when i click that thing.
From a stop floor it hard (you probably wont hear it click cause the car is on and theres lots of noise) and see what kinda result you get. You can also push that button while moving and it will get you moving faster, faster.
Also, try using the manual selector to max out the gears. You can keep her redlined in gears longer and shift when you want to shift by using the selector. (well, pretty much)
Try the "hard floor" from a stop and then come back and tell us what happened. If its still "weak" then, well, I don't know cause that phrase is relative... ... but you might have a problem we can try to diagnose then.
Just wanna make sure the seat to car interface is working properly b4 moving on to other items !!
Old Jan 24, 2003 | 01:44 PM
Tank's Avatar
Just took it out and tried it, doesn't seem to help with accelerating from a stop, but while moving, it sounds like it goes back a gear and starts moving a bit faster.
Never noticed that little button before, heh. Before when I floored it I didn't push hard enough to depress that button
Thanks for the info =p
Old Jan 24, 2003 | 11:32 PM
Tank's Avatar
Man.. just got this big chunk of metal in my tire, gotta get a new one now =/
edit: deleting attachment for a smaller version
Old Jan 24, 2003 | 11:33 PM
Tank's Avatar
Old Jan 30, 2003 | 12:44 AM
soldsep's Avatar
87 300 E
i call it kick down button. when was your last tune up? and smog test? sometimes those smog test guys adjust your retard. I have that same problem right now. Except when its cold out. i accelerate alrite but not very happy with it.
Old Jan 30, 2003 | 08:26 PM
Tank's Avatar
last tune up was a month or two ago, not sure about smog test
