W140 rims on W124
Old Mar 11, 2009 | 11:28 PM
abakja1's Avatar
2009 Nissan 370z Sport; 2005 AMG E55; 2005 Subaru Legacy GT LMT; 2004 Honda Element EX
W140 rims on W124
I have a set of 19999 S Class 16x7.5" rims with 235/60/16 tires with 51 offset.
Will this fit on a 1995 e500 with spacers?
If so, I think I need to purchase some 12mm lugbolts with a 14mm ball seat and maybe that is 50mm long in front as the S class are 144 ball seated lugbolts about 1 3/4 inches threaded.
Can anyone help or provide any info what is need to do this if they have done this already?
Thanks!
Kevin
Old Mar 11, 2009 | 11:42 PM
bluecoupe's Avatar
30mm is a big spacer! Make sure you buy quality if you go this route.
Old Feb 13, 2013 | 02:31 PM
TobiasMB's Avatar
10 C63/p31, 84 190/5.8L, 14 Audi Q5 TDI, 03 Suburban /8.1, 87 Porsche 944/358" 77 Ferrari 308 Dino
The S class used to use 14mm bolts so you better look closer to what you want to put on a car that uses 12mm bolts.
Now if you will need a 30mm spacer, get a 14mm/12mm spacer/adapter and that should resolve a possible problem.
