300te compression test for oil loss?
In the old days (1960's) we did compression tests on our cars. Kinda fun, informative...usually scared us with the #'s.
What is the procedure for doing one on the 300te? Specifically!
This is what we 'used to' do:
1. remove all plugs
2. screw tester in #1 plug hole
3. crank 4-5x, write down #, repeat.
4. do this for all cylinders.
To test for rings, we would squirt some oil into the plug hole and repeat test...if # is different, possible ring problem
---Is this the method? Do I crank 3-5x? What are 'normal' #'s? How do I 'really' check for ring problems? How much oil do I inject into the top of the cylinder?
Thanks.
Presently, while I'm waiting for the weather to get decent to repair this, my 300TE 4matic wagon is not only leaking oil into the coolant, but also down the side of the engine at about the rate you mention in your original post. You can run like this indefinitely, but oil inside your coolant hoses will eventually break them down and possibly rupture.
You can get great compression readings even with a faulty head gasket on these cars. I did a leakdown test in the beginning and got great percentages for a car with over 200K. However, the engine has to be running and at normal temperatures for these faults to occur....so that will rule out your normal compression check and leakdown test for a leaking head gasket.
If you really do have bad rings, then a normal leakdown test will suffice...much better than just a simple compression check. These cars engines are not made with voodoo, but they do have some minor quirks. I would bet that you have the head gasket issue, because these engines go a long time without ring trouble-with a complete head rebuild at around 200K (providing your head gasket doesn't leak prior), the 103 engine is design capable of 450K.
Kevin
to tell - still cold out).
1. remove all plugs
Thanks.
At night get a buddy behind you about 2 or 3 car lengths. Sit and idle at a stop for a minute or so and then punch it. Watch in your rear view for smoke in the headlights of the car behind you.
Like shep said look for leaks in the head gasket. Are you leaving any puddles or do you smell oil. I just completed a head gasket replacement on my 94 320 and it was pushing about 2 quarts a week. Look at the corners of the head on the passenger side. Often times the oil leaks while driving and then when you stop the leaks are minimal and don't leave big puddles. Let us know what you find.
GED, how's your beast running after the head gasket repair?? Idle, MPG, power etc...
Kevin
I'm gonna turbo the 3.0 single cam after I replace the head gasket, suspension parts, brakes etc. I read somewhere that the faster you go, the less the power steering actuates. Anyway at speed, it sure feels like rack and pinion. These cars are a dream past 100mph...they really have that 'safe' feel. On 'the road trip' last summer, my car had no problem hitting 140mph in NV/NM a number of times. How much more it has than that, I'm not sure (if any).
Kevin
