Electric Windows
Old Jan 31, 2003 | 03:49 AM
mmarks's Avatar
260e
Electric Windows
'88 LHD 260e.
Passenger side electric window does not work (hasn't since I bought the car).
When I depress the switch, there is a click after a few seconds (whether I press to go up or down) but the window does not move.
Any suggestions & if needed, how do I remove the motor ?
Also, the drivers side has now decided to slow down to the point that it takes a whole minute to put the window up or down (used to be fine until this morning)
Many thanks,
Mike
Old Feb 1, 2003 | 09:44 AM
MB4JH's Avatar
86 300e
Question You can try cleaning the switches...
If that does not work, you probably need a new motor(s).
Did you spill anything on the console lately?
Old Feb 2, 2003 | 08:45 PM
pkmaven's Avatar
Mercedes-Benz 300D TURBO 1987
Slow or not working windows
If you brought your car to a Mercedes dealer they would tell you that you need new regulators. The motors rarely go bad during the life of the car but the regulator channels dry out and the plastic "foot" that travels through it siezes. Remove the door panels and lubricate the regulator channels with atf.P.
Old Feb 3, 2003 | 07:14 AM
mmarks's Avatar
260e
Thanks for the info, I know how to remove the door trim, could you give me any more information on lubricating the regulator (where is it & what does it look like ?)
