wagon suspension question
I remember reading a thread over at the mercedesshop.com forums about swapping them out. If you do a search you might find something.
The wondering at speed is most likely the rear control arms as the bushings get worn and broken -- unfortunately requiring the entire arm to be replaced as the bushings are welded/molded on. Easiest way to check it is to have someone drive the car forward from a stop...if you see the rear wheels move back slightly instead of staying locked in the middle as they should then that's the problem.
