Question on Over Voltage Relay
What exactly is the problem you are experiencing? Obviously stalling, but under what conditions? Idle only? Cold? Warm? All the time? What other items have you replaced for this car so far?
Cold start, idle is an issue, once in awhile, morning mostly (cooler starts). It idles low, will start when pushing in clutch to slow/downshift. It used to have a hard time restarting after after shut downs more then around 2 hours, like something got heat soaked. But haven't had any problems with that lately.
It stalled after warmed up on the freeway once after warmed up, just cut off. Restart, dies after 3-5 seconds, just stops, after numerous tries of restarting, like it goes to timed cycle changeover (which shuts it down). I rattled the comp and OVR behind the battery, started up fine and drove home. Stop at a shop to ask a mech if they had any OVR's, while moving it to show him, it did the same thing, started and did after the same cycle. MOved the OVR around and it has ran fine since, till I changed it out today, moved it around a bit and all is good.
I've sprayed and soaked the throttle body and took the what I think is a pressure regulator, fuel cannister prior to injection pump off and blew it out. This I think cured the "heat soak" issue, or seemed to.
So, my problems are-
Cold idle issues
Inadvertant engine shut off (which I think is just a bad wire connection, broken wire somewhere)
I've played with LS motors, and the engine shutoff is like a VATS on the LS motors, starts for a few seconds and just stops. Prior owner (2 before me) had a pretty indepth alarm system installed, not used or hooked up, from what I can tell, but alot of stuff is still there. Might have to look at some of that crap too.
Not too concerned, as it seems reliable, but I got the wife and kid coming to visit and would rather have dependable transpo instead of dropping money for a rental.
Any possibility of testing another one? Shutting off on the freeway just screams OVP. Of course though, check your negative battery cable as they can get brittle with time. Then check the voltage regulator on the alternator and see what condition the brushes are in.
I would also pull off the idle control valve and shoot some carb cleaner into it. It can get all bugged up and dirty inside and can cause rough idle. With the air assembly off, it's two bolts and its in your hand so it shouldn't take more than 2-3 mins.
On the OVP, I really think its a wiring connection. Only time it does stall is when it falls out of its holder, which was broken when I bought it. Need to some double sided tape to stick it back up.
