Something is draining my battery
Old May 26, 2009 | 07:32 PM
eazye1973's Avatar
1997 MB E420
Hello,
Something is draining my battery and am hoping someone can help me figure out the culprit. Started about 2 months ago, woke up one day and the battery was totally dead. Thought the battery was bad so I went ahead and bought a new battery. Starts right up and runs great but the next morning the new battery is totally drained! I recharged it but again the next day the battery was totally drained again. I have since replaced the voltage regulator but did not sove the problem. I had taken fuse #9 and it seems to be holding charge but when I put it back it starts to drain it. Anyone know what the problem might be?
Thanks!
Ed
Last edited by eazye1973; May 26, 2009 at 07:34 PM. Reason: forgot to add car type
Old May 26, 2009 | 07:34 PM
eazye1973's Avatar
1997 MB E420
BTW i have a 1989 300E.
Old May 26, 2009 | 08:19 PM
ps2cho's Avatar
E
Well what does fuse #9 control? It should be easy to figure out if you are sure taking fuse #9 out stops it draining.
Old May 28, 2009 | 02:15 PM
Mosselmann's Avatar
W124
have you fitted a radio recently? i had this problem then i bypassed the ignition switch. I wired it so radio would work with no key in - to find it drained my battery
