Sunroof Linkage
Thanks all,
Chris
//www.w124performance.com/images/W124_sunroof/http:
//www.detali.ru/cat/oem_mb1.asp?TP=1&F=124052&VIN=
good discription of how to do it
haven't tried it yet but sounds do able
this was in shopforum do a search there is more there
but this is the most complete
good luck
Let this be a lesson to everyone, keep your sunroof tracks and linakges well lubricated and clean.. a bit of grease goes a long way.
the links provided are useful, but i cant stress how careful you have to be with these parts as they were assembeled with no intention of being serviced, as an example that front wind deflector that pops up after all the years and miles develops hairline fracutres on the sides from constant stress, if you try to remove it by prying those two side rubber mounts it will fall apart, and without it off, you cant get to the screws holding the sunroof track on... just be very careful and patient, and take photos of every thing so you cna put it back on correctly
