Performance Cylinder Head
Old Feb 11, 2003 | 12:42 AM
soldsep's Avatar
87 300 E
So i think my cylinder head is cracked. Anyone know where i can get a good one for a reasonable price?
thanks in advanced
-p
Old Feb 12, 2003 | 09:37 PM
89CE's Avatar
1989 300CE
My buddy might still have one for sale. Ill let you know about the price and shipping if youre still interested.
Old Feb 13, 2003 | 02:16 AM
soldsep's Avatar
87 300 E
yea i would like to know the price.
Old Feb 14, 2003 | 08:19 PM
ashman's Avatar
2004 C240, 2015 GL350 Bluetec
I have seena brabus m103 engine head for sale on ebay... might want to check in on it...
Alon
Old Feb 14, 2003 | 09:08 PM
Tri Star300E's Avatar
89 300E
There is a place here in Georgia called Cylinder Head Exchange that will sell you a reman and take yours as a core even if it's cracked. You should be able to find a reputable reman business close to you. Buying somebody's junk off Ebay is about the most stupid thing you could do.
Old Feb 15, 2003 | 02:46 AM
89CE's Avatar
1989 300CE
I saw that Brabus head on Ebay a while back. From what I recall, the head was newly built by Brabus and didnt look anything like 'junk' to me. By the way, my buddy's head was just sold.
Old Feb 15, 2003 | 03:54 AM
soldsep's Avatar
87 300 E
whats a reman?
Old Feb 15, 2003 | 09:42 AM
89 300E
Originally posted by soldsep
whats a reman?
A reman is a 'remanufactured' part. Either your head can be done or you can find a place that will 'swap out' with you. The head is checked for dimensional correctness, airtightness, the valve guides are relaced and the valves brought back into spec. Hd nine done recently and was pleased with the result. I really can't see the return of just putting a Brabus head on a tired engine and expecting noticeable gains.
Old Feb 16, 2003 | 12:34 AM
soldsep's Avatar
87 300 E
how much did you do it for?
Old Feb 16, 2003 | 11:33 AM
89CE's Avatar
1989 300CE
Had mine done for $350 includes labor to and installation of all new guides and seals (parts included). If you know your head is in good condition, I would not swap it with another one just to get it the same day. I had mine done simply because I knew that my head was in perfect condition and the service was needed because of worn guide seals. I changed my head gasket simply because you have to at this level, not because I needed to due to a blown gasket. With that in mind, I knew that my head wasnt warped or damaged. Doing a swap isnt advisable simply because you dont know the history of the head youre getting. Now, if your head is cracked, damaged, etc., then I would do the swap.
Old Feb 16, 2003 | 02:21 PM
soldsep's Avatar
87 300 E
ok so i guess im gonna hafta looka round for a place that will swap one with me. now a swap doesnt cost 350 does it? would it be more?
Old Feb 16, 2003 | 02:54 PM
89 300E
Looking back, I think we should have asked this sooner...
What makes you think yours is 'cracked'?
Old Feb 16, 2003 | 06:28 PM
soldsep's Avatar
87 300 E
mechanic told me it was cracked. zim at topline in burlingame, ca
Old Feb 16, 2003 | 09:13 PM
89 300E
Not trying to make this complicated, but..
What are the symptoms?, coolant and oil mixing, engine skip??? What's going on?
Old Feb 16, 2003 | 09:34 PM
TNblkc230wz's Avatar
C320 Coupe
It is really hard to distinguish between a cracked head, cracked cylinder, and blown head gasket without taking the head off. The symptoms are usually the same unless you visually see a crack on the exterior of the head. Cracked cylinders are very rare. The most common problem is a blown head gasket.
I wouldn't buy the head unless a competent machine shop has looked at yours and said it was unrepairable, unless you want a performance head such as the Brabus
Old Feb 17, 2003 | 12:23 AM
soldsep's Avatar
87 300 E
hmm. ill have another mechanic look at it but these are the only problems i notice. oil leak. burns a lot of oil. at stop light car shakes alot. feels like it is gonna die but not that bad. not sure how to describe that. i feel that i use a lot more gas then usual. thats it.
Old Feb 17, 2003 | 10:57 AM
89CE's Avatar
1989 300CE
A cracked cylinder is an easy fix if youre rebuilding the entire engine. The cylinders are sleeves that can be pressed out of the block.
Old Feb 17, 2003 | 02:27 PM
soldsep's Avatar
87 300 E
so your saying that i might as well rebuild my engine cuz its probably easier?
Old Feb 17, 2003 | 02:42 PM
Cap'n Carageous's Avatar
89 300E
Personal question...
What is your level of automotive repair knowledge? The reason I ask is that engine rebuildig is a LOT more involved and costly than reworking a cylinder head. If you were not already aware of that, then you should not attempt to diagnose and repair the engine yourself. Find a reputable shop and say 'call me when it's finished' or an experienced individual willing to guide you through the process. Special tools and knowledge are essential.
Old Feb 17, 2003 | 09:20 PM
soldsep's Avatar
87 300 E
Alot of knowledge suspension wise Not much knowledge engine wise. Ill have someone check the cylinder head if its cracked.
hopefully its not.
maybe i just need guides and seals to be replaced? ok ill come back after i know whats really up.
