Tune up... Did i miss anything?
1994 E420
Hey guys, ill be doing a full tune up on my 420 this upcoming week. I ordered new plugs, wires, air filters, fuel filter, and a transmission filter and pan gasket. I'm also doing an oil and filter change and draining the radiator and putting new coolant in. Just wanted to make sure i didnt miss anything. Thanks
I just put new brake lines in the rear so i know that the pads and rotors are good.
1 Post
w211 & w124
How important is it to change the wires at the same time you're changing the plugs? I just bought a kit with plugs, dist. cap and rotor and am going to give it a shot this weekend but didn't buy new wires.
1994 E420
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
Also thanks on the diff fluid change idea
1 Post
1991 560SEC Teal 1989 420SEL Ice Blue 1984 500SEC White
I only use MB fluids, and no its not difficult. Call your local dealer, they are pretty reasonable when it comes to fluid changes. Almost as cheap as what you could do it.
New fluid is a great place to start. The plug wires can be done later but best to do while its on your mind/list.
Good Luck
Replace all fluids whenever I get a new used car.
