Very HIGH RPM= HIGH MPG
i am wondering that my 1990 wagon has a high RPM, when the car is at idle the RPM is around 500 to 600 rpm which looks normal , but when i am driving it around 60mph the RPM is at 3K RPM , when i speed up to 80 MPH the RPm will me 4k RPM .. this seems not to be normal , because my other w124 if i run it at 80MHp the rpm is 3K RPM....
i did a change oil already, with ( oil additives)
added fuel injector clean & even sprayed the carb & injector
but nothing changed
i am thinking changing the distributor, rotor, fuel filter & O2 sensor
i hope this will help the RPM go down to normal
ANY SUGGESTION & ADVICE ??
thanks
i am wondering that my 1990 wagon has a high RPM, when the car is at idle the RPM is around 5k to 6k which looks normal , but when i am driving it around 60mph the RPM is at 3K RPM , when i speed up to 80 MPH the RPm will me 4k RPM .. this seems not to be normal , because my other w124 if i run it at 80MHp the rpm is 3K RPM....
but nothing changed
thanks
At 80MPH then, you should be somewhere in the neighborhood of 3500-4000RPM in 'D' which is overdrive. Your RPM is established by the gearing of the car. You can't change that with carb cleaner. There could be reasons your car is missing @idle or on the hwy, but that won't change RPM values for your motor and final drive ratios.
Kevin
the car shift like butter smooth ...
thanks for the info
Boiled down; What is the normal RPM of a 1990 wagon @80MPH. I was telling him what my '92 4Matic RPM runs at about 80MPH in overdrive and at 140MPH. He was also stating that his 300e runs less RPM than his wagon @80MPH.The carb cleaner and his tranny shifting smooth was a curve ball, I believe.
Can I get an Impartial ruling on all this??
Kevin
Kevin
