Hooking up an AMP.
the shemdogg
also nice to see another bay area 124 enthusiest.
ANOTHER THING: how did you get pass the back seat? does it fold down or did you unscrew it or what?
thanks
sold
the bottom of the back seat has a clip on either side at the bottom. Stick a flat screwdriver on top of the clip and push down while pulling up on the seat. for the top half, there are three 10mm bolts on the sides and center. Then push up and it will slide off. There is a rear grommet on the right with wires and vacuum tubes you can feed your wires through. Its a pretty big job.
the shemdogg
