Removing interior vents?
The bulb goes into the switch to open/close the vents does not illuminate and I have the cluster off so I figured why not as I have it apart. It looks like it is not part of the dash, but a separate item....but I don't see how it comes off.
Anybody know?
Anybody know?
Kevin
Okay the way the mechanism works is pulling it up/down. For the top ones, put a coathanger through and pull DOWN, and for the bottom, pull UP. Do one side at a time, not top then bottom because you gotta lever out one side first.
The bulbs are part # 2721 @ autohausarizona. $0.73c each.
After getting it out, I swapped bulb and works great now
If you are gonna buy, get like 10 because they are used throughout the car. Dash lights, console lights etc...
the vent out. easy peasy.
a'
You still have to pry them up with a small flat-head or something similar. Slipping coins in is just an extra step. All you have to do is do the two left clips, pull the left side out a little, and do the right side. Easier peasier.
