Need help wagon self leveling systempics pls
Old Jul 26, 2009 | 06:08 AM
epowers777's Avatar
85 euro w124 300d non turbo black on black......coming soon hx35 turbo intercooler
https://mbworld.org/forums/e-class-w...ed-advice.html
Please go to this thread for pics. I need a picture and the length of this missing link so I can make my own. Called lots of junk yards and no wagons! 9posting down second and third picture. Its under the right rear of your car between the pumkin and wheel.
Old Jul 27, 2009 | 06:13 AM
epowers777's Avatar
All the wagon owners and no one wants to help.
Old Jul 27, 2009 | 03:46 PM
roach_juts's Avatar
2000 e430( w210),1979 240D (w123), 1992 300e(w124), 1990 mitsubishi galant VR4
I got no pics ... check this out if it would help
Here's a sort of "how to" replace the rear spring accumulators on W124 estates - this method was worked out by a matter of trial and error - mostly error but may well help other people who are faced with replacing the spheres.
if you are thinking of attacking the job, there are 2 ways to do it, one is the "proper way" which Mercedes book at 5 1/2 hours labour but realistically for the home mechanic will take longer as there are a couple of "special tools" required to do it this way
secondly and in real terms much quicker is to do it the way I ended up doing it and assuming you don't need to grind the old nuts off should take no more than two to three hours actual work.
Parts you will need
2 x suspension spheres - cost about £140 the pair
2 x rubber seals - they sit on the base of the spheres and seal the bodywork - cost pennies
2 x new hydraulic pipes to connect the levelling unit to the spheres - cost about £12 the pair - don't try and make your own there is an insert in them that is designed to slow the flow of fluid
1 x new bracket for the self levelling unit - you may not need this but best to be prepared - cost about £5
4 x 16mm copper compression washers - cost pennies
6 x 10mm nyloc nuts
2 x 1.5 cm m6 (I think) metric fine thread bolts and a tube of loctite
2 litres of MB hydraulic Oil - ZHM fluid (no other fluid - certainly not the cheaper LHM that citroens use) - cost about £17
tools required,
axle stands
torque wrench
10mm hex key (preferably socket driven as you need to torque use a specific torque)
11mm socket - to remove the remains of the old unions
11mm spanner - to re tighten the hydraulic unions
10 mm socket with a pretty narrow wall on the socket side to remove the retaining nuts for the spheres
10 mm open ended spanner to detach the self levelling unit
10" extension drive
3" waggle joint extension bar or universal joint extension
hammer
chisel
cross head screwdriver
optional tool - power drill with mini grinding wheel/attachment or a dremel grinder
rough work plan (isn't hindsight a wonderful thing?)
1, remove the floor section immediatle behind the rear seats - it's held in with 6 cross head screws. lift it from the middle quite firmly - it may seem like it doesn't want to give but it will - it may bend slightly as it's only thin steel but it's easy to straighten
2, with the car up on axle stands attempt to loosen the 6 x 10 mm bolts that hold the spheres in place - don't take all of them right off - you just want to loosen them at this stage to make sure they will move. If they don't or the captive bolt breaks loose - like 3 of mine did you'll need to grind them off from underneath the car once you have detached the hydraulic pipes
3, remove the two bolts that hold the levelling unit in place - the top one is a swine to get at as it is behind hydraulic pipes.
4, place a large bowl under the car and loosen the passenger side banjo union on the base of the sphere (10mm hex key). Let the oil drain into the bowl - you are going to get wet here as you are releasing pressure on the system so do it carefully and when the car is cold - that oil gets bloody hot!!!!!! The "official" method is to attach a pipe to then loosen the screw on top of the self levelling unit to drain the fluid - you'll see why this "alternative" method is easier once you get under the car
5, now repeat that on the other side - do not bend the large pipes out of the way even though it's tempting as it will cause you problems on reassembly (don't ask)
6, when the oil has stopped dripping chisel the unions for the small bore hydraulic pipes off flush with the old spheres and cut them with pliers at the levelling unit, remove the unions from the levelling unit using an 11mm socket and plug the holes to stop any drips - the new spheres you have bought will have plugs in that you can use for this purpose. Pull out the remains of the hydraulic pies and after noting which way they fit throw them away
7, now you can remove the spheres, if the come out easily great - if not be prepared for some awkward grinding of the nuts.
Once they are out, the bracket for the self levelling unit will be freed, so throw that away
If you've got the time to spare I'd take the car off it's jacks/axle stands and leave it overnight at this point with a bowl under the self levelling unit, remove the plugs and let the rest of the oil drip out - it seems to be the most effective way of draining the system completely. Bear in mind that with no pressure at all in the system the car will sit very low on the rear springs whan you remove the jack so don't use a bowl that is too deep
Reassembly is the reverse, put the spheres and the new bracket in and fix them with the 10mm nylocs - torque up to 20 nm
fix the self levelling unit to the new bracket with the small loctited bolts.
connect the shorter of the two new small bore hydraulic pipes to the drivers side sphere and the levelling unit first - you'll see why
then connect the feed to the passenger side.
Connect the banjo unions to the base of the spheres using a copper washer on either side of it and torque up the hex bolts to 30nm - do not try and go any higher!!!!!!!!! and be very careful not to cross thread them - it's far too easy as the spheres are very soft metal - if you do cross thread them you'll need a 16mm metric fine tap to clean the thread (once again don't ask).
With that complete, let the car back down onto the ground and fill the reservoir with oil - you will need about 1 litre initially.
Make sure the screw top is on the reservoir but leave the filler hole open, load the boot - you need a weight of at least 120kg to set it up right so a couple of friends sat in the back is perfect. Get someone to start the car and hold the revs at 2000 for about a minute whilst the suspension rises and add the rest of the hydraulic fluid as required. Once the level of the car and the fluid has stabilised, switch off, unload the car and start it again to check that the levels are fine.
Check for any leaks, take for a test drive and marvel at how smooth the car now feels.....
these spheres have a "life" of about 100,000 miles and if your rear suspension feels harsh or lacks damping they are the most likely source of the problem.
Dispose of the old spheres carefully - before throwing them away you should drill a 3mm hole in the top of them to release any residual pressure/gasses - wear goggles and drill slowly with a lubricated drill bit.
Old Jul 27, 2009 | 04:17 PM
epowers777's Avatar
That is good info but my self leveling system works fine I just need to know the length of that lever.No one is willing to look under there car for me?
Old Jul 27, 2009 | 11:54 PM
pifcat2's Avatar
300TE / 300E / 300CE
I will look Wednesday but you should use a factory part. There was a wagon in my local PNP but they scrapped it before I could get more parts.
Here's more info on another forum (more techs their): http://www.peachparts.com/shopforum/...d.php?t=257454
Old Jul 28, 2009 | 05:08 AM
epowers777's Avatar
Sweet ty did you see the pics of the device? Apic and length would be great!!! thank you!
Old Jul 28, 2009 | 09:34 AM
ds190's Avatar
300TE, 300CE
suspension pull rod
So here it is for $42 plus shipping:
http://catalog.peachparts.com/ShopBy...ll+Rod&mode=PA
There's a pic in that page.
Old Jul 28, 2009 | 10:04 AM
eatmuppets's Avatar
2x 1994 E320 Wagon 124.092
If you intend to fabricate one, you should make it adjustable, like the factory part. If you want to fabricate a non-adjustable link, you could go through the process of adjusting the system to the correct height, make sure the lever is in the neutral position, then measure the length. It's likely to be a different length from one vehicle to the next (so a photo may not help).
There's a drawing of the assembly in the AMG suspension conversion document at the following link (page 17):
http://www.2phast.com/500e/techdocs/AMG_W124_conversion_SLS.pdf
I recommend following ds190's advice above.
Old Jul 28, 2009 | 07:15 PM
epowers777's Avatar
I could Kiss you!!! Im making it fully adjustable. I got all the peices to make it will give pics ty so much.
(Dont worry im married)
Old Jul 29, 2009 | 03:21 AM
epowers777's Avatar
I see there are modification to the self leveling system. Is that a dealer recall ? Will they still do it?
Old Jul 29, 2009 | 05:01 AM
epowers777's Avatar
Here are pics of the link im making.
As you can see all I needs is a peice of all thread got to get at ace hardware what you think?
Old Jul 29, 2009 | 01:04 PM
eatmuppets's Avatar
Those are gorgeous. I can only see the threads on one of them, but I assume they are all right-hand. The original part is reverse-thread on one end, to allow adjustment in place... yours should do the trick however, as long as you don't mind disconnecting one end to do the adjusting.
Old Jul 29, 2009 | 03:59 PM
epowers777's Avatar
I dont think they are reversed. Ill just take it off and adjust it.
Old Jul 30, 2009 | 12:43 AM
pifcat2's Avatar
Measured the arm but can't say it's 100% accurate given the angle and my viewpoint of the tape measure. Even if I used my caliper I'd still eye the centers of the links. I measured ~3 3/16". Here's a bad pic, my camera didn't work close up under the car...
Your links look nice but the question is will they hold up to the forces. They look thinner than the OEM links and appear to have more swivel and no dampening like the tie rod type.
Attached Thumbnails Need help wagon self leveling systempics pls-dscf5234.jpg
Old Aug 1, 2009 | 04:58 PM
epowers777's Avatar
Here is a pic of the part. Its coming along good! 3 bucks invested.
Old Aug 2, 2009 | 12:44 AM
pifcat2's Avatar
Looking good, care to share your source?
Old Aug 2, 2009 | 04:14 AM
epowers777's Avatar
Well just found parts laying around my shop. Go the all thread from ace hardware.Pm mrif need some.
Old Aug 2, 2009 | 12:26 PM
pifcat2's Avatar
Just curious, those links could work for many custom things...
Old Sep 16, 2009 | 06:22 AM
epowers777's Avatar
well I installed the link and not the luck I wanted. The ride is still bumpy. Is there a way to reset the system? Or I have to change the accumulators. This is the right part I need?
Is there anything else I need. Do I need to replace the filter? Does anyone know a diy with pics?
Please give me ideas
