Is mine sportline swaybar?
While I was under my car, I just checked the front swaybar visually, and the ends are narrow and the middle is thicker.
I heard that regular e series swaybar is the same size from tip to the middle.
What do you guys think?
For example I upgraded my car (E 220 Coupe) to sport chasis suspension and the new swaybars and thicker:
- front: is 1 mm thicker in center area and 3 mm thicker at the ends.
- rear: is 3 mm thicker.
Of course, I also needed to change rubbers.
I guess mine is just regular one because it's thicker in the middle and narrow at the end, which is different from what you said.
I will check the code.
Thanks.
My car has the sportline badge on the fenders, but no sportline shift ***, no sportline interior. However, it looks lowered and suspension seems pretty tight. I can put 3 fingers(I have girl's hand) in the gap between tire and fender. That is way I just checked the swaybar whether it's regular one or sportline, but like I said, what do I know.
I will check the code and let you know.
Thanks.
