Vibration when first cold start
Old Sep 20, 2009 | 06:28 PM
gorillajin's Avatar
1994 e320 sedan
Hi,
I have this weird issue when engine is cold.
I start the engine first in the morning, the whole car vibrates like crazy for 2~4 seconds and during the time the idle is below 500. It all becomes fine after 5 sec....
No problem when the engine is hot.
Any advice on this?
Thanks.
Old Sep 21, 2009 | 06:13 AM
epowers777's Avatar
85 euro w124 300d non turbo black on black......coming soon hx35 turbo intercooler
Well I got a different engine than you But I know that the temp sensor controls your computer. Mine was bad and started that issue. Is it missfireing on start? Also I came across some interesting info. Look at your egr valve.and take it off the metal pipe that goes to ur intake clogs up clean it out. I will try to find the link for you.
Old Sep 21, 2009 | 12:08 PM
gorillajin's Avatar
1994 e320 sedan
Thanks epowers.
Where is the temp sensor? If the sensor is bad, does it cause any other symptoms?
I will check the egr valve.
Old Sep 21, 2009 | 12:30 PM
neanderthal's Avatar
First, how do you start the car?
I turn the key to on, wait a coupla seconds to let the fuel pumps pressurise the system, then start the car.
If you just start it and you fuel pressure regulator is bad you may get that shaking at idle.
Then i'd go to new spark plugs, fuel filter, wires, fuel injector cleaner.
Then stuff like the cold start injector, temp sensor etc
Old Sep 21, 2009 | 12:39 PM
gorillajin's Avatar
1994 e320 sedan
I turn the key to On and wait the buzz sound go off, and start the engine.
Hum...what is cold start injector??
Thanks.
Old Sep 21, 2009 | 12:50 PM
Ok, sounds like you start the car the same way I do.
I meant cold start injector circuit.
Use the search feature for "cold start."
Old Sep 21, 2009 | 12:54 PM
gorillajin's Avatar
1994 e320 sedan
Thanks for the advice.
I will start seaching with "cold start" here.
i just read how to clean EGR valve, and it seems like I need an air compressor to blow air in the pipe, which I do not have.
Do I have to buy the air compressor to just clean the EGR valve and pipe...???
Old Sep 21, 2009 | 01:10 PM
gorillajin's Avatar
1994 e320 sedan
OK, the car got worse.
I started the engine and it stalled. I started it again and as usual the whole car vibrated crazy for 3~5 sec.....
Old Sep 21, 2009 | 03:15 PM
epowers777's Avatar
What ever you do dont blow the egr with air I busted mine doing that. Take a cable or something and put it in your metal pipe that goes to the intake to see if its clogged. It usually cloggs at intake. Im still trying to find the link hopefully I will find it tonight. Clogged egr pipe give ruff idle like ur explaining.
Old Sep 22, 2009 | 02:04 PM
gorillajin's Avatar
1994 e320 sedan
Thank you for the tip.
Can this problem be the fuel regulator? Car stalls only in the frist start in the morning. After it starts, never stalls and the idle is very steady.
