A/C Compressor won't engage
Its filled with 32oz....so there should be no reason it should not be engaged by now...It would begin to click at like 18oz then fully engage at ~30oz
How do I check the pressure switch? Anybody done this?
EDIT: Forgot to mention I am using Enviro-safe 12a as refrigerant.
Nobody here know how to hotwire the pressure switch temporarily to make sure the compressor hasn't blown? I looked at the wires, but couldn't make anything out of them...
I also checked fuse + replaced it for good measure to no avail.
A) Compressor dead
B) Pressure switch not functioning
C) Climate Control Unit broken.
Gotta be one of the 3....
I found the FSM PDF on it:
http://www.ps2cho.net/downloads/MB%2...ate/83-542.pdf
What does it mean "jump the two terminals"? Bridge them? I'm always weary when playing with electrics with engine running...
Ps when you click ac will ur fans kick on? if so button is good
Robert
Do I just need a piece of wire to bridge pin 5 & 7 to jump the relay?
Wtf? That makes no sense at all. The only way that is possible is if the 260E's A/C Unit is blown, ALONG with something else in the system.
So I have eliminated Klimate Relay, jump pressure switch, A/C Control Unit. Argh!!
