Need 300TE specs, for rear suspension modification
Old Oct 10, 2009 | 12:58 PM
pifcat2's Avatar
300TE / 300E / 300CE
Anyone have any of this info:
  • Front vehicle weight
  • Rear vehicle weight
  • Front and rear unsprung weights if they are disproportionally high
  • Spring rate
  • Spring motion ratio (the amount that the spring moves per unit of wheel travel)
  • Shock motion ratio (the amount that the shock moves per unit of wheel travel)
  • Mount configuration
  • Angle off vertical that the shock mounts
  • Either the desired extended and compressed lengths, or the mounted length as the vehicle sits on level ground
