Oil level indicating lamp
1992 300ce
Lamp doesn't come on during lamp check, (ing position 2). Figured no big deal, must be the bulb. Pulled cluster, changed bulb, still doesn't come on. Switched a few bulbs to make sure bulb was good, bulb is OK. What to check next? Can't figure why it doesn't light up. Anyone ever have a similar problem? Thanks,
Mike
Mike
1992 300ce
I guess that will be my next move, I'm not sure how one interfaces w/ the other. If I disconnect the sensor wire the light should come on, correct? Thanks.
1 Post
1994 E320 (current)
Not sure how similar the 300e is to my 94 320 but my light is always on because there is a harness that sends the signal from the sending units of the Oil PSI and level sending units and it is bad which shows no pressure and no oil. Might be something to check into for you. It is a cluster of three wires on mine. Just a thought.
