LED Tail Light Wiring Help
Joey.-
After much headache, I came up with (what I think) is the best possible setup given the way the circuit boards are designed. I have the center two lights as running lights, and the outer two on each assembly as brake lights. Maybe I got a bunk set, but the center squares in each light are not very bright.
I will check later and let you know which colors are where.
So, if you purchase a 6 pin plug and replace the 7 pin plug and insert each wire just like the passenger side, you will have one left over, which should be the rear fog, easy enough to test using the multi-meter. The wiring config and colors on each side are the same, but I have seen variances between years, especially on pre 90 models, hence why I mentioned to test with the multi-meter.
I think the are two choices: 1.- Like 2Phast says, would be to get a 6 pin plug - same as the plug on the rear passenger side- use it on the driver's side, and simply eliminate the 7th plug and fog light.
2.- Modify the existing 7 pin plug with a dremmel tool, remove the plastic guide post on the new LED and just plug it in. Either way, I will loose the fog light capability.
I might do a DIY sticky on this. I am also converting all of the interior lights to LED, including instrument panel and all switches. The lights within the switches are LED already (very, very, small) but I just want them brighter and perhaps I will color code by function. I think it will look great. I am trying to keep from "rice-ing up" - or (kraut-ing up?)the car too much. However, I do like the mods that 2phast has done to his car. And, if it's OK with you, I would like to ask you about your sources - i.e. rear spoiler??
So far, I have changed the headlights from DOT to Euro style, and the overall profile and clean lines of the car have really shone through as I believe that the car's true design in appearance incorporated these lights. The mod to use the DOT headlights - for the US market- really made the car look like an AMC product and barely tolerable from the front. I get a lot of good comments all of the time. This is the true Teutonic look.
2Phast, do you know where I can get the specs and wiring diagrams for the switches that I refer to above? I need to know know the size of this small LED, output, and voltage. Also, since these are polarity sensitive, I need to know how to determine this on an LED. Take one apart- the toggle part- and you'll see what I mean. I do have a stereo microscope that I can use to make the mods myself. Or, are these switches already modified available in the market??
Thanks, Guys!!
Joey.-
As for the switch's, well the WIS isn't going to be that detailed, so that won't help you. I did take my alarm LED switch out, take it apart and mount a superbright LED in it (my windows are tinted and you couldn't see the original LED). No way to tell much about the stock LED, no markings on it.
As far as the LEDs in the switches, I got the right size - 3 mm, but I am not sure of the voltage; however, I assume that they would be 12 vF (volts forward). I know that there has to be a resistor on the (+) side of the led. Fry's Electronics have these LEDs with integrated resistors. Flavors are only red and green. Not what I want. When I get one working I will let you know. This is going to require microsurgery... .
I will probably do a sticky DIY on both the tail lights and switches.
By the way, are you using the "Blue and Laurels" center caps on your wheels? If not, would you like to sell them to me?
Joey.-
Joey.-
All of the switch's I have taken apart already have the resistors in them to reduce voltage, so you can just unsolder the original LED and solder in your new LED. I have not had any issues doing this, but then again, have only done a couple LED swaps.
My center caps are the MB caps w/chrome star, I took them apart and when my wheels were painted, the caps were painted at the same time. You might be thinking of the E500 wheels that were on my car 6 years ago, those and the caps are long gone
