Flickering Headlamps
Old Dec 25, 2009 | 08:59 PM
Stuttgart1946's Avatar
'96 C280
Hi,
This is my first post to MBForums and after a little browsing I don't see any leads to a solution to my problem, so here goes...
Upon starting up my 85 300D Euro (same as 86 300E) the headlights flicker a bit. It seems the issue stops after a few minutes of running. The relay, 126.542.00.32, is the only thing I see that is correlated with the exterior lights. All fuses are free of corrosion, alternator output is normal, and battery is good. The headlight bulbs are H4.
Is this a grounding problem? Does anyone have similar experience with this sort of problem?
Thanks for any input,
Jack
