e320 not starting consistently
Old Jan 18, 2010 | 10:30 AM
sasjzl's Avatar
1995 e320 Wagon
Hi all,
I have a 1995 E320 where the starter is not turning consistently. Turn the key and all the appropriate dash lights come on but not click from the solenoid and no starter turning over. Turn the key again and it starts up normally and runs normally. I will be checking the connections to the starter and the solenoid (and ground) but am wondering what would be the smartest thing to check next? Battery is fully charged.
Since I am not hearing a click at the solenoid my prime suspect is the positive wire to the solenoid is not a good connection. Is there a safety switch on the auto shift lever which would prevent the starter from turning over if it does not think it is in PARK?
Thanks very much,
Jim Lee
1995 E320 Wagon
Old Jan 20, 2010 | 11:28 AM
latief's Avatar
1993 300e 2.8 - M104 Engine, SOLD; S320 2000
Yes, Neutral safety switch might be suspect. Put the tranny in N and try to start to see if it improves...
also, how is your alarm system?
