Multiple problems
Old Jan 27, 2010 | 11:06 AM
RUFAZZ's Avatar
(3)CL600's, e350 wagon 4matic, (2)300ce
Multiple problems
I changed a blown head gasket now I have a problem with the central locking system, cruise control and a out of control revving problem.
I have changed the over voltage relay, cap, rotor, wires, plugs, O2 sensor, checked for Vacuum leaks and had no luck!!!!
At this point I am ready to pull the engine and start again. Obviously I would rather not do that sooooo I am looking for anything that will help me with this seriese of problems cause I love my car and I intend to drive it 500k miles and I am only half way there.
Thank you
Adrian
Old Jan 27, 2010 | 11:41 AM
ps2cho's Avatar
E
The locking system is vacuum based, so look for leaks.
What is wrong with the CC exactly?
Can you explain the revving problem further? I would look at the idle control valve for any high reving problems at idle.
Old Jan 27, 2010 | 01:15 PM
Kestas's Avatar
95 E320 Cabriolet, 108K
It does sound suspiciously like a massive vacuum leak.
Old Jan 27, 2010 | 05:23 PM
RUFAZZ's Avatar
When I try to use it the car just takes off, as if it has no idea what speed I am going. I replaced the idle control valve when I did the OVP relay.
Old Jan 27, 2010 | 05:24 PM
RUFAZZ's Avatar
I am inclined to agree with you on that, but I cannot find one
Old Jan 28, 2010 | 11:21 AM
RUFAZZ's Avatar
UPDATE:
I was driving this morning and lost power, the engine stumbled for about 30-45 sec as if it were out of gas, then back to normal. What is going on?
