Drink Holder Malfunction
Old Feb 5, 2010 | 12:34 PM
tarheel76's Avatar
2004 E320
The drink holder on my 2004 E320 fails to rise when I depress OPEN. It worked perfectly the last time I used it. Is this a DIY fix? I'm very mechanically inclined with basic instructions? If anyone out there has had this problem I would appreciate your suggestion(s).
Tarheel
Old Feb 5, 2010 | 01:44 PM
ZedStyle's Avatar
Youngtimer
wrong forum, man.
this is pre-cupholder land, where cars are built with one purpose... to be driven...
no time to sip on a starbucks when you're rounding a corner at 80mph, no need to sip on a dasani when the open road lies before you beckoning you to drive.... drive..... drivvvvve.....
Old Feb 5, 2010 | 02:35 PM
2PHAST's Avatar
500E Signal Rot
cup holder is between my legs, so there is no margin for any coffee spillage, haha
Old Feb 5, 2010 | 02:48 PM
Brian_I.'s Avatar
w211 & w124
You can pull it out and then clean it up and put a tiny bit of grease on the parts that slide up. Common issue with the w211...
Old Feb 6, 2010 | 11:10 AM
tarheel76's Avatar
2004 E320
How does one pull it out when it is stuck in the down position? I don't want to get too aggressive and end up breaking it. Putting clear lithium grease would be a good suggestion. I appreciate your reply.
Tarheel
Old Feb 6, 2010 | 01:59 PM
neanderthal's Avatar
One starts by posting in the correct forum!!!!!!!!!!!
Old Feb 6, 2010 | 03:34 PM
rivcal4life's Avatar
92 500e, 95 E34 525I Touring
Are you talking about the w211 cupholder, or 2phasts?
Old Feb 6, 2010 | 03:36 PM
raymond g-'s Avatar
99 E320
if it's just a tiny part, you only use a tiny bit of grease.
Old Feb 6, 2010 | 05:01 PM
2PHAST's Avatar
500E Signal Rot
Hahaha, I was thinking the same thing
Old Feb 6, 2010 | 06:15 PM
tarheel76's Avatar
2004 E320
OK I give up. What is the correct forum to address this problem?? I've only had this MB for three months so please cut me some slack and steer me in the right direction. Thanks.
Tarheel
Old Feb 6, 2010 | 08:49 PM
2PHAST's Avatar
500E Signal Rot
Tarheel
This is the W124 section (1985-1995 E-Class) you might want to try the W211 section.
