Contemplating a swap
Old Feb 9, 2010 | 09:40 PM
JSe420's Avatar
1994 E420
So I have been thinking about doing a swap in my 420 for a while now. The opportunity has presented itself to swap in a motor and tranny from a 500SL. I can get a deal on the motor and tranny and probably even the diff if I wanted it as well. Just wanted to find out a little more info on what else I would need to make this happen. I have the entire 500SL at my shop so taking random odds and ends wouldnt be a problem. Any suggestions?
Old Feb 10, 2010 | 01:46 AM
Saijin_Naib's Avatar
1990 300ce 24v I6
My suggestion: Do it.
You have the strengthened front clip for the V8 already, so the added weight of the 500sl block (if it indeed even IS heavier) should be no issue.
Only snags I can think of would possibly be ECU/MAS/ECM/Fuel Pump. If you have the whole car though....
Old Feb 10, 2010 | 07:54 PM
JSe420's Avatar
1994 E420
ya I knew I would definitely need the ecu and probably other minor electrical things. I'd like to find out if I could use my rear end or if i would also need the diff from the 500.
Overall, I think it would be a pretty cool swap especially if I have the SL at my disposal.
Old Feb 13, 2010 | 11:20 PM
David Hendy's Avatar
'97 Renntech E60RS
Its already been done:
http://www.peachparts.com/shopforum/...d.php?t=250175
Get a 3.07 diff from a '91-'92 300CE as well!!
