K1 shift kit
Old 04-09-2010, 07:29 PM
Benzo87's Avatar
300E
K1 shift kit
I have a 1987 300E. Im pulling the engine to replace it. i wanna do a shift kit on my trans and i dont know where to buy a k1 shift kit. Anyone know a web site where i can buy one for a good price???
Old 04-09-2010, 08:48 PM
ps2cho's Avatar
E
Get it from your local dealership. I think I paid $9? PN# 126 270 44 77. They identify it as a "thrust pin".
Why are you pulling the engine to do it? You realize you can just drop the pan to do it right
Here's how to do it
http://www.peachparts.com/shopforum/...=271601&page=3
Half way down
Old 04-18-2010, 12:44 AM
Benzo87's Avatar
300E
im replacing the engine. i spun a crank bearing on a connecting rod and destroyed a piston. shattered to peices. so wen i had the tranny out i wanted to do some things to it. and it just started to surge between 2nd and 3rd. do you know what would make it not want to shift into 4th sometimes. its only done it twice but it wouldnt shift into 4th under a load.
Old 04-18-2010, 07:57 PM
ps2cho's Avatar
E
If you have it out and it won't shift into 4th, you'll need a rebuild with the bands further in. I didn't go that far into mine, but its only a few steps further.
Old 04-21-2010, 05:32 PM
Benzo87's Avatar
300E
arent the bands what u pulled out just a few steps into your rebuild post? the first one was burnt up. if its gunna be a big deal im not gunna bother i dont really have the money to put into the tranny. i jus had to buy a used engine and gaskets.. its only done it twice i think. and to wut i know the tranny has never had a service. im just guna do the shift kit and a filter. any suggestions on wut trans fluid i should put back in it. every time any 1 i know thats done a tranny service and put new oil in it always have shifting or slippage problems after. i was just going to filter the old oil real good and reuse it..
Old 10-07-2010, 03:33 PM
novastaraspen's Avatar
300ce 1992
trans is sipping and I only have 106k on trans. its a 1992 300ce, has the k1 shift it been usefull?
Old 10-19-2012, 06:27 AM
Jared.C.H's Avatar
1989 300E
Reason why they slip is because you replace the old dirty gritty oil which that dirt is part of the bands and clutches but with new clean oil that acts as an better friction reducer causing the slippage. Normally you can buy an additive that can help reduce this or stop it (like snake oil) but mostly reduce it. If you see brace in your pan when you change your filter then your tranny is on its way... but dont reuse your old oil.....I recommend the oe transfuild from MB or the compatible stuff from Redline. your napa or orielys should have it.
Quick Reply: K1 shift kit
